audio out of sync after exporting to h.264 mov file
Tristan Wira
on Dec 4, 2008 at 4:46:57 pm
hi guys just a quick question
i have some problems with the sync of audio and video
in the edit everything is 100% on sync
only when exporting it sseems that the further the playback of the clip progresses the more the audio gets out of sync
the audio source i imported in adobe cs3 premiere pro it's sample rate is 44.1 khz
could that be causing my problems? do i need to import an acceptable audio file into premiere pro cs3 with a sample rate of 48khz to solve my problem?
tnx for you much needed advice...much appreciated!
