Removing Echo
Ken Zukin
Removing Echo
on Sep 26, 2008 at 6:58:55 pm
I shot an interview at a museum using a good quality lavaliere. Level is good, but voice has much echo. Anyway of removing echo using standard audio filters found in Final Cut Pro / Soundtrack???
John Fishback
Re: Removing Echo
on Sep 26, 2008 at 7:48:59 pm
Unfortunately, there's nothing you can do to remove the echo unless you know someone at the NSA :). However, using EQ to reduce certain frequencies where the echo is most predominant might help. Select the clip you want to filter then AUDIO FILTERS > APPLE > AUGraphicEQ. Double-click your clip and open the Filter Tab in the Viewer. You'll see many sliders you can tweak to try to reduce the echo. Start by cutting the low freqs and try boosting 3150Hz to 5kHz. You have to experiment because each space is different. You'll not remove the echo. Hopefully, you can reduce it's effect.
If you find settings that help, apply them to all your clips. Good luck.
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
© 2018 All Rights Reserved
