Audio problems with Panasonic HVX-200
Rodney Morris
on Jul 21, 2008 at 8:40:01 pm
Hey Ty - it's been a little while since I've posted here.
I've been doing some work recently with a local studio that shoots with the Panasonic HVX-200 P2 camera (using P2 media). I did a job for them today and heard a low level "beeping/chirping" sound in the return audio from the camera. The audio is clean when I am monitoring in standby, but as soon as the record button is pressed, the beeping/chirping begins and, worst of all, is recorded into the file (I was hoping for a headphone amp issue). It's very rhythmic, about once/second, and consistent in level. It's a low level noise, in fact so low that the producer/videographer could barely hear it and didn't can the shoot because of it. We did spend 15 - 20 mins troubleshooting, trying different input settings, different outputs from my mixer, connecting the mic directly to camera (bypassing the mixer), etc. all to no avail. I'm pretty sure I'll be able to notch filter it in post (if needed) so I'm not going to lose any sleep over this, but I do want to see if anyone else has had this issue with the HVX series cameras. I'm not familiar enough with the menus on the HVX to know if there is something I'm missing in the camera, but I'm thinking that's not the issue. We did two shoots today - one HD, one SD, both with the HVX-200 and both had the beeping/chirping.
My equipment today was Schoeps MK41 mic overhead through a Sound Devices 442 feeding a single Panasonic HVX-200.
I've tried to list all pertinent information, but if I've forgotten something, please ask. I'd like to figure this out.
Thanks to all who post.
Jan Crittenden Livingston
Re: Audio problems with Panasonic HVX-200
on Jul 21, 2008 at 9:02:45 pm
Contact pbtscservice.com and explain your issues, don't forget where you are located and the serial number of your unit. They will give you the next step in resolving the issue. It seems to happen with certain mic/input device combos. But just contact them and they can fix it for you.
Best,
Jan
Product Manager, HPX500, HVX200, DVX100
Panasonic Broadcast & TV Systems
Rodney Morris
on Jul 21, 2008 at 11:11:33 pm
Thanks Jan - will do.
Freelance Sound Technician/Mixer
Vince Becquiot
on Jul 22, 2008 at 8:02:59 pm
Had one of ours fixed last week for this issue. Panasonic has been on top of it, and the turnaround was just a few days including shipping.
Thanks Jan.
Ty Ford
on Jul 22, 2008 at 12:28:21 am
Thanks for stepping in Jan,
I was busy earlier today passing a kidney stone. (TMI, I know!)
Wasn't there also something about certain P2 cameras that beeped if larger memory cards were used?
Regards,
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
on Jul 22, 2008 at 12:40:37 am
Hi Ty,
Sounds like a bad day. ;-)
As far as the bbeping with larger cards, that is not the issue. It seems more focused to the combination of camera and peripherals paired with the input.
I trust you are okay!
Best,
jan
Ty Ford
on Jul 22, 2008 at 1:22:38 am
Hi Jan,
So that's a different problem than this one?
For the past three days, I've been on set with a project shooting with
the HVX200, which writes onto P2 cards. We were using a 16GB card
when I encountered this problem. I was monitoring audio from camera
via a breakaway cable plugged into my Sound Devices mixer. I was NOT
using any wireless. Every time we rolled on this particular card,
there was a very low-level, random yet constant beeping in my
headphones. While trying to troubleshoot, we played back the take (so
easy to do with this camera!) and I could hear the same low-level
beeping on playback, as well. We only had this problem with one of
our three P2 cards. We fixed it by reformatting (erasing) the P2
card.
Luckily, it was NOT the camera, it was the card, and you should try
switching cards or reformat the card, which takes about a minute. You
can even dump the card down to a laptop before reformatting, in case
the take was good for picture and camera really wanted to keep it.
I'm not sure how common this problem is, but suffice it to say that
when shooting on P2, I'm going to crank my headphones way up every
time we start a new card to listen for the low-level beeping.
Also, this is REALLY odd, but I ONLY could hear the beeping when using
my external mixer. While troubleshooting, I switched over to the
camera mic and tried rolling on that, and I didn't hear any beeping
there. This could be related to the fact that P2 cards by default
record audio into FOUR channels (stereo camera mic and external mics)
when you have external mics plugged in, but (I think) only onto TWO
channels when there are no external mics present. Not sure how that
would alleviate a bad card. (Maybe I just couldn't hear the beeping
because the internal mic is so crappy!)
Long story short, try reformatting or swapping out the P2 card.
And thank goodness for camera departments that allow audio a few
minutes to troubleshoot on set!
Or this...
Michael Clark
I had this happen also on a recent gig. 2 hvx200's being feed by zaxcoms. It only appeared on 1 camera. I had thought it was the Zaxcom(rental), but clearly that was not the issue. We were rolling double system, so we didn't bother tracking it down thoroughly. The noise WAS recorded in my instance. But not all the time. Which I originally thought it was RF issues, since it didn't happen all the time. Same clicking sound, very fast. If anyone wants to hear it, shoot me an email, and I'll send you something short. Yet another reason to keep our recorders working, and not trust cameras to record our audio:) Mike
Aug 6 2007, 6:23 pm
abedolin...@gmail.com
View profile
More options Aug 7 2007, 1:38 am
> Mike
Exciting news! Soundriven's (or his son's) advice turned out to be
spot on. The HVX I shot on today actually had both issues described
here - the rapid clicking as well as a high-pitched beep. Now that I
think of it, the high-pitched beep was present on the 16GB card and
the clicking was on the 8GBs. I haven't heard back from the first
project on whether it's showed up in FCP yet.
Both issues were resolved by putting the P2 card in slot 2. Reminds
me of how mysterious PCI card issues could sometimes be resolved by
switching them to a different slot on the motherboard (PC users,
anyone?).
The DP's theory is that it's an error with the new drivers everyone's
just had to install in order to use the 16GB cards. He said he knew
someone to at Panasonic he could notify, so maybe we'll get some
feedback.
Thank you all, and especially Soundriven - I owe you all a drink. Let
me know if you're ever in NY!
Rodney Morris
on Jul 22, 2008 at 12:47:05 am
Ty, I'm sorry to hear about your kidney stone. I hope you are feeling better now. If you've passed it completely, then I KNOW you're feeling better.
Ty Ford
on Jul 22, 2008 at 1:09:17 am
Hope so, thanks.
Ty Ford
Jurgen Bakker
on Aug 6, 2008 at 4:56:31 pm
Hello Jan,
Reading the replies about the problems concerning the HVX200, I'd like to ask you a question. Although it's not so much a audio-related issue, as it is a technical issue.
Shooting in P2-mode, the image breaks up about every 7 seconds. (scrambled image) It's only for a few frames, but it does it about every 7 secs. At the same time, the audiochannel swing out to the max. level, giving a short noise, as if a TV channel is off the air. (now what I mean?) After trying starting up for a few times over, this notification pops up: SYSTEM ERROR REC RAM OVERFLOW.
After that, it's back to the same story again.
Could you help me out?
Kind Regards,
Jurgen Bakker (The Netherlands)
on Aug 6, 2008 at 5:16:26 pm
Sounds like you need a service center.
Best,
Jan
Jurgen Bakker
on Aug 6, 2008 at 5:28:59 pm
Thanks for the quick reply Jan,
I'll try and contact a service-centre in The Netherlands. (I hope it won't mean sending it to the U.S. or so. (gulp)
Thanks anyway,
Greetings
Jurgen
