Simple Question about Sampling Rates
Matthew Abourezk
on Jun 21, 2008 at 4:14:19 pm
Hi all,
Does converting a song from 44.1Khz to 48 Khz physically change the length of a song?
matt
Talkingbox Digital Media Group, Inc.
http://www.talkingboxdmg.com
(203) 327-6617
Greg Fatianow
Re: Simple Question about Sampling Rates
on Jun 21, 2008 at 6:07:22 pm
Hi Matt,
No, converting your song from 44.1 to 48 khz will "not" change the length of your song. If it was originally recorded at 48 khz however, it will give you a slight increase in sound fidelity.
Will Salley
on Jun 22, 2008 at 11:55:16 pm
If you have hardware in which the sampling rate can be manually changed (Pro Tools) it is possible to have a playback "speed" slower or faster. Say you recorded an audio file at 48khz, bounced it to a file with a setting of 44.1, then imported it back to the original project (which would still have hardware clocked at 48khz), it would playback faster - and thus - shorter.
Most hardware devices will automatically detect the sampling rate and set the playback rate accordingly.
Primary System Info
Mac Pro 2x3.2 Quadcore - 10.5.3 - QT 7.4.5 - 6MBram - nvidia8800GT - SATA internal & external storage - Blackmagic Multibridge Pro (v6.7)- Open GL 1.5.6 - Wacom Intous2 tablet
