how to wire a PPM ...
Matthias Halibrand
on Apr 26, 2008 at 10:37:26 am
Hi guys,
I would like to install a PeakProgramMeter (PPM 1206 manufactured by RTW) which I happend to still have to my newly installed Kona3-Breakout-Box. This has two cinch-connectors for stereo out.
The PPM has only 5-pole DIN-connectors, which are differently labelled, so which one to use, and what pole goes where?
They are labelled as follows:
1.: 175 mV - 30V/> 47K
2.: 1,55 V/> 47 K
3.: 155 mV/> 42 K
The first one has a PTC-resistor (I'm not sure if this is the right translation) on each side, which can be adjusted.
So, which one is the right one for the analog line-out of the Kona3-breakout-box?
What pole-number inside the DIN-plug do I have to solder to what pole of the cinch-plugs?
If I want to use the same out for monitoring, too, how would I do that, since the PPM doesn't seem to have an out.
Thanks a million for your help,
MatzeHali
Matthias Halibrand
Re: how to wire a PPM ...
on Apr 30, 2008 at 10:26:49 am
Is really noone of the Audio-Pros able to answer that question?
Come on guys!
Thanks anyways,
MatzeHali
