Balanced audio?
Zach Marion
Balanced audio?
on Feb 11, 2008 at 5:51:05 pm
I was going to purchase a Sennheiser ew 112-p G2 wireless lav kit to use with a Canon XH A1. The receiver has an 1/8" output jack. The kit provides a small 1/8" to XLR cable to be used between the receiver and the camera. Is my audio going to be balanced? Should I be afraid of the infamous Mr. Buzz?
Thax Clave
Re: Balanced audio?
on Feb 11, 2008 at 8:34:36 pm
Very short runs of unbalanced should be OK, but if you are in the wrong location (strong RF field) you COULD have some problems.
Roland Heap
Re: Balanced audio?
on Feb 12, 2008 at 9:13:28 am
Well, according to Sennheiser spec the output on that 1/8" jack is balanced, so you should be fine, theoretically up to quite a long cable length.
I suspect it uses the same pinout as on its larger balanced jack cousins.
Ty Ford
Re: Balanced audio?
on Feb 12, 2008 at 4:27:34 pm
Thanks for that Roland.
If the plug has two non-conductive bands, it very likely is balanced.
Regards,
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Thax Clave
Re: Balanced audio?
on Feb 12, 2008 at 11:06:26 pm
But the camera does not have 1/8" balanced INPUTS.
It has XLR mic or line-level inputs.
And an 1/8" STEREO (I assume this because it has a built-in stereo mic right next to this input) mic input on the handle.
If plugged into a stereo 1/8" input, the balance signal will be ruined.
OP needs to build or buy a proper cable(s) to connect the mic to the camera.
Ty Ford
Re: Balanced audio?
on Feb 12, 2008 at 11:22:53 pm
Sorry Thax.
I thought that was a "given."
Regards,
Ty
