Lavalier Mic with portable recorder?
Eric Marx
on Dec 10, 2007 at 7:27:56 pm
I have an iriver ifp-799 and want to use it with a lavalier mic since it has a 1/8" mic input (not just line).
Can anyone tell me whether a Countryman EMW with a 1/8" (3.5mm) connector will work with this? The EMW seems to be designed for wireless systems.
If not, are there any other high-end lav mics you could recommend that would work for recording conversations in noisy environments?
Eric
Matte
Re: Lavalier Mic with portable recorder?
on Dec 12, 2007 at 4:54:01 pm
The Countryman (and most other pro-level mics, condenser-types) require battery power (1 volt, or so) to operate.
Wireless transmitters provide that power on their inputs.
A portable recorder (iRiver, in this case) will likely NOT provide this, unless it specifically says so.
