omf to aaf
fr
omf to aaf
by
on Aug 30, 2007 at 9:35:32 pm
hi,
maybe you audio proffesionals can help me, i hope so
i'm looking for a way to convert an omf session with embedded audio to aaf with embedded audio
i was thinking about protools, or is there other software that can do this?
protools can import omf - can it output an aaf session of this omf?
does protools need a plugin for this? fe digitanslator?
any tips would be greatly aprreciated , i need omf from a fcpro system into a ppro system, and ppro does only work with aaf
thx, Fr
lee grainge
Re: omf to aaf
on Sep 3, 2007 at 11:11:38 am
Hi there,
Pro tools does indeed do what you need to. Digitranslator will convert OMF to AAF - I cannot remember exactly but I think Logic also does. Well I have in the past imported an OMF into Logic Pro. The importer in Logic VERS 7.0 seemed to not be able to read all the order that Pro-Tools wrapped them. Basically some files were not in the T/C position they should be.
I originally bought Digitranslator 2 (do not buy with VERS 1) then soon realised that I needed the DV Tool Kit II which has this and many other options that you normally only find on the HD series of PT.
I don't know about any other Apps.
Hope this helps.
fr
Re: omf to aaf
by
on Sep 3, 2007 at 11:49:58 am
ok thx Lee,
i have a friend with protools ans digitranslator so i will doe the test
Fr
