Pro Tools and DAC100
Al_egoboo
on Aug 20, 2007 at 3:58:58 pm
I am running protools HD3 on a Mac G5. I am sending the video out to a Datavideo DAC100 Card and then going into an LCD TV via component video. But I am only getting a black and white signal.
Can anyone help?
Alan.
Ray Palmer
Re: Pro Tools and DAC100
on Aug 20, 2007 at 11:26:39 pm
[Al_egoboo] " Card and then going into an LCD TV via component video. But I am only getting a black and white signal."
I am not familiar with your I/O or monitor but I have seen this a dozen times. If you are sending analog component output and your monitor is set for composite, you will get B&W. The green channel is the luminence channel and it only has black and white information.
Check to make sure that your monitor is also set to component, not composite.
Ray Palmer, Engineer
Salt River Project
Phoenix, AZ
602-236-8224 office
There are three types of people in this world, those that can count and those that can't.
Peter Groom
on Aug 23, 2007 at 9:19:31 am
Yep, component is separates, composite is all signals composited into 1 video signal which is where the problem will lie.
Look for a non rgb input
Peter
