Capturing audio from a dat into FCP
on May 9, 2007 at 3:08:01 am
Hey all,
I have to "load" sound from a Tascam DA-P1 portable DAT recorder into Final Cut and I'm wondering if anyone has experience with that, who might be able to point me in the direction of proper settings, things I should be looking out for, and of course (if possible), a step-by-step guide to gettin' it done.
It looks like I'll have to get these DAT tapes into FCP with the "voice over" tool. I have the DAT hooked up: stereo to 8th inch mini, line in...
Does this sound like the correct way to go about it? Is there a way to log using the voice over tool, or will logging involve another step?
Thanks for your help,
Re: Capturing audio from a dat into FCP
on May 10, 2007 at 10:19:30 pm
You can do it that way.
If your DAT and Mac have optical ins and outs, you can simply capture to a file on the Mac and import the AIFF's into FCP.
Another good way is to record the DAT to a DV or other digital tape (that your system can handle) and then capture the tape (and keep it as another master.)
You will THEN have a tape with TIMECODE that can be re-captured in the future.
© 2018 All Rights Reserved
