AAF / MXF / OMF
Peter Groom
AAF / MXF / OMF
on Apr 13, 2007 at 6:13:23 pm
HI
Is anyone using AAF or MXF files as a preference to OMF 1 or 2 yet.
If so which video platforms output AAF / MXF and what are the real
benefits?
Peter
Will Salley
Re: AAF / MXF / OMF
on Apr 15, 2007 at 5:34:20 am
I don't use OMFs much any more unless it's strickly an Avid>Pro Tools transfer. I do use XML filetypes with Final Cut Pro and MXF files which are generated by the Panasonic P2 cameras. The benefits of both are that they comtain more metadata and will hopefully be implemented by a large group of manufacturers (I guess we'll see at NAB).
I'm not sure about AAFs - although I see so many different filetypes I'm not sure what some of them are.
System Info - G5/Dual 2 - 10.4.8 - QT v7.1.3 - 8GB ram - Radeon 9800Pro - External SATA Raid - Decklink Extreme - Wacom 6x8
Peter Groom
Re: AAF / MXF / OMF
on Apr 15, 2007 at 7:05:38 am
HI Will
What audio DAW are you using with FCP XML
Peter
Will Salley
Re: AAF / MXF / OMF
on Apr 16, 2007 at 3:41:34 am
Logic Pro
