Mac Quad G5 and 5.1 Surround Sound (Dolby)
Sjon Ueckert
on Feb 25, 2007 at 6:55:07 am
Does anyone know of an interface that can be used to output 5.1 Audio from a Macintosh? I have found a few (Gryffin Firewave and M-Audio 410) but I don't know if they work with Final Cut Pro or DVD Studio Pro. I don't need to mix 5.1 (although I can with Logic) I just need to be able to hear it. I have a Yamaha Surround Sound system that requies 6 RCA miniplugs, so that would have to be the interface's output. Inut can be either optical out or fiewire.
Sjon
Will Salley
Re: Mac Quad G5 and 5.1 Surround Sound (Dolby)
on Feb 26, 2007 at 9:14:13 pm
The 410 should work with FCP and DVDSP. The PCI based M-audio 5.1 card should work equally as well.
http://www.samedaymusic.com/product--MDOREV51
System Info - G5/Dual 2 - 10.4.8 - QT v7.1.3 - 8GB ram - Radeon 9800Pro - External SATA Raid - Decklink Extreme - Wacom 6x8
rcPics
on Mar 13, 2007 at 8:36:13 am
If you want to go the ultra-cheap route, you can take the audio converter/controller of this headphone setup:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=...
..which accepts coax or optical digital in (the G5 has optical in/out), and hook up stereo mini-plug to RCA adapters to the analog outs (C/L/R/SL/SR/SW) to get separate analog outs.
