shooting in 24p, should audio be recorded at 24fps or 30fps?
sandib
on Dec 1, 2006 at 7:07:04 pm
Hi, we're shooting on a varicam at 1080 24p. Should audio be recorded at 24 fps or 30 fps in order to sync properly?
Thanks.
Chaos Wrangler
Re: shooting in 24p, should audio be recorded at 24fps or 30fps?
on Dec 1, 2006 at 9:48:32 pm
If you are recording audio on the camera it is a non issue just go straight in. If not it depends on your posting process. I would go with 30fps and at 48.048 K (this will play back at 48 K in video world). I would check with your post dept. most problems show up when everyone is not on the same page.
Best,
Drew
Chaos is the beginning of everything.
Frank Nolan
on Dec 2, 2006 at 8:52:48 pm
Not only check with your post department but you should also check with the camera department. AFAIK the varicam only shoots in 720 not 1080.
