Can you adapt a radio mic to work hard wired?
Eric Susch
on Jun 29, 2006 at 12:26:06 am
Anyone know if it's possible to purchase (or make) an adapter so that you can use a Countryman B6 lav that has a Lectrosonics connector on the end and hard wire it? Would a short 5-pin to XLR adapter cable work and allow you to phantom power the mic directly into a mixer or recorder? Anyone tried something like this?
Will Salley
Re: Can you adapt a radio mic to work hard wired?
on Jun 29, 2006 at 2:56:01 am
I saw something like this on the Lectro site.
http://www.lectrosonics.com/manuals/mca5xtd.pdf
I have a cable that makes this connection, however, I think the bias voltage of the B6 is incorrect for standard 48v phantom. I haven't used it on the B6 - I don't want to damage the mic.
I think it depends on the model of Lectro transmitter for which the mic is wired. Here's the info from Countryman's site for the UM400.
Lectrosonics UM400
Switchcraft TA5F
Pin 1 = Shield
1.5k ohm Pin 2 to 3
3.3k pin 3 to white
tom
by
on Jun 29, 2006 at 11:30:14 am
Before I would try anything, I would contact a good audio company such as Trew. i know you can do this with the correct connection
good luck
Tom
Ty Ford
on Jun 29, 2006 at 12:06:44 pm
Contact Countryman directly and ask about getting a "link." COuntryman makes links for all of their mics. It's a TAF to xlr/power supply that does just what you want. I have one.
Ty Ford
Ty Ford's "Audio Bootcamp Field Guide" was written for video people who want better audio. Find out more at http://www.tyford.com
Eric Susch
on Jun 29, 2006 at 4:01:31 pm
Thanks everyone!
Looks like there's more than one way to do this. ...And I'm glad I don't have to break out the soldering iron ;-)
