Bias Soundsoap
LandofNid
Bias Soundsoap
on Apr 25, 2006 at 1:29:21 pm
I have used Soundsoap many times in the past as a plug in in FCP. I always manually dial out the noise because if I use the learn noise function of Soapsoap it works but...when I play play the clip there is a delay of about 1 second before soundsoap kicks in. You can hear the room tone in all of it's glory for about a second then Soundsoap kicks in and the noise disappears. Why does this happen? Does this happen to anyone else?
I tried putting nodes on the audio for the first second of the clip that dropped the audio out. Soundsoap still waits a second after the first part of the clip with audio to kick in. Any ideas or suggestions?
-Nicholas Bierzonski
Editor/DVD Author/Java Boy
http://www.finalfocusvideo.com
LandofNid
Re: Bias Soundsoap by the way
on Apr 25, 2006 at 1:41:49 pm
I forgot to mention that unlike when I use Soundsoap in Peak if I hit the learn noise button...the default parameters do not change. So also can't tweak them and make adjustments.
