LCD for Pro Tools room
on Apr 17, 2006 at 7:37:11 pm
Hello All-
Any insight into LCD TVs for a high-end Pro Tools rig? I need something with near-zero latency (won't fall out of lip-sync). Any ideas would be great!
Vidiots, NYC
Don Greening
Re: LCD for Pro Tools room
on Apr 18, 2006 at 3:44:33 am
Last christmas I sat in on an audio sweetening session for the pilot of a new half hour TV series. The footage was shot in hi def 16:9 24P. The Pro Tools guy was using a Pioneer 50" plasma. Nice.
- Don
Aurora Support
on Apr 25, 2006 at 9:06:37 pm
The only catch with high-end flat-panel TVs and monitors is that there is usually a significant delay through the input processing circuitry. You'll want some to do some testing, to get the timeline offset dialed in, and if you're using a DV converter, you'll never get consistent offset while looping..
The Syncheck is a great peice of gear for calibrating your offset, and a card like
[Begin Shameless Plug :-) ]
the Aurora Fuse-X is a great option for outputting video to your new display. Fuse-X plays any QuickTime compression format from within any QT-compliant application without interference or interaction with the application.
- Mike Stroven
Aurora Video Systems
© 2018 All Rights Reserved
