Setup for G2 100 wireless and Z1U
Harvey Z
on Apr 12, 2006 at 4:46:42 am
We are using a Senn G2 100 system next weekend and wonder if there is anyone out there that would recommend a setup for our Sony Z1U?
We'll be doing interviews with the wireless receiver going into XLR input 1 and recording on both channels (1&2). Any suggestions for level, trim and wind on each of the inputs?
For the Senn G2 100 what would be a starting point for transmitter sensitivity (sensit level)and receiver output level (AF Out).
Many thanks
Harvey
Matte
Re: Setup for G2 100 wireless and Z1U
on Apr 12, 2006 at 11:39:40 am
This is kind of like asking for the timing settings on a '62 Buick.
You must set the levels to the individual situation.
Set one channel on the camera to the "normal" level (peaks to around -12) and the other channel set 3dB to 6dB lower.
That way if one channel peaks and distorts, the other should be cleaner.
No need to add wind filter (unless there IS a wind or low-freq. problem at the shoot).
The level settings on the mic fully depend on the talent's voice, mic-placement, etc.
Harvey Z
on Apr 16, 2006 at 8:13:05 pm
Got more info from another forum. This might hepl other Senn100 G2 users...
Radio mic always puts another layer (or two) of levels settings in the audio chain.
1) In the transmitter you have to set the levels or gain (SENSIT in the menu) so, that the loudest sounds do no overload the transmitter. The setting is quite coarse in steps of 10 dB, from 0 to -30 dB. With the standard lavelier it is usually -20dB, or -10dB if there is only quiet conversation expected. Lower -20dB setting is safer, if the sound level is high enough to overload the transmitter the case is lost in the beginning and can not be helped later. There is the levels meter on the transmitter, the last segment means overload and there is also the yellow AF PEAK light which never should light up.
2) On the receiver end you have to set the level with which the reciever puts the signal out to camera or recorder: mic or line level. There are no two settings for this, but the AF OUT menu choice lets you set the level from -30dB to +12dB in steps of 6dB. If you want to use line level signal (+6dB or +12dB) you should set the camera inputs to LINE (front of the DVX100) and use high AF OUT -levels like +6 or +12dB. This bypasses the mic preamps on the camera and is the better choice. If you insist in using mic level signal, you should try -30 or -24dB levels and set the camera inputs to MIC. Whith either setting the audio level dials should work at the normal 11-12 a'clock position and give normal working levels with some red lighting up at the loudest passages.
With just the camera (or recorder) you only have to worry about one level setting, with radio mics you have to worry about two level settings, plus have to make sure the signal levels are right fot the chosen input mode in the camera (mic/line).
One more thing to note - when you swap out the batteries, as you should before every shoot, the unit will reset and lose your settings, so remember to go back through everything so you don't get crappy results.
Check out this G2 tutorial online at...
http://dvcreators.net/products/sennheiser_wireless_movieframe.htm
Harvey Z
