mini to XLR is ther a difference
Legend
on Jan 11, 2006 at 8:30:07 am
I recently purchased a lectrsonics uhf 100 reciever kit. It only has a mini out, is there any sound quality loss mini to XLR as opposed to XLR to XLR. It is for recording interviews and such.
Matte
Re: mini to XLR is ther a difference
on Jan 11, 2006 at 12:35:34 pm
The main difference between "mini-plug" and "XLR" connections is not "quality of the audio"... but it has to do with NOISE PICKUP.
With UN-balanced cables (2 pins/wires), of which mini-phone plugs and RCA phono plugs are a part, there is SINGLE inner conductor wire, wrapped (encased) by a shield wire. In UN-balanced cables, the conductor AND the shield both help carry the "signal".
If the cable is used in an area that contains stray audio interference (radio & cellphone transmitters, AC power radiation), each wire (conductor and/or shield) can pick up a slightly different amount of the "noise" and THAT causes the a potential for the noise to get amplified and recorded along WITH the audio that the cable is carrying. (Noise = BAD).
The (BALANCED) XLR cable has 3 pins/wires (for mic and audio use, anyway).
There are TWO inner "conductor" wires, wrapped (encased) by a third "shield" wire.
With BALANCED cable, the shield does NOT carry any of the audio signal.
If the 2 conductors DO pick up any stray audio interference (radio & cellphone transmitters, AC power radiation), they are BOTH at the same "potential" in relation to the shield (both conductors INSIDE the shield) the interference tends to "null-out" to "zero" between the two, and not "get into" (become a part of) the audio that the cable is carrying. (No Noise = GOOD).
This is VERY important with longer cable runs from mics to mixers or camcorders.
(There can also be a small loss of high-frequencies with longer runs of UN-balanced cables as well).
HOWEVER...
In the case of a very short cable length of under 10 feet, or so (like the short link from a wireless mic receiver mounted to a camcorder) it most-likely will NOT cause any quality problems if you are using an UN-balanced link from mic to camcorder.
But, always (ALWAYS) wear good headphones and monitor your audio (listen for any NOISE pickup) every time you're recording audio you intend to use.
Legend
on Jan 11, 2006 at 9:05:25 pm
Thanks, it sounds like you really know your audio.
Ty Ford
on Jan 12, 2006 at 12:57:59 am
Mini jacks and plugs can be balanced or unbalanced.
I would guess that Lectro uses balanced outs. Check with them to be sure. If it is a balanced (3-conductor) output it really makes no difference whether its an XLR ot a TRS.
Regards,
Ty Ford
Ty Ford's "Audio Bootcamp Field Guide" was written for video people who want better audio. Find out more at http://www.tyford.com
Matte
on Jan 12, 2006 at 1:17:05 am
Yes, the Lectrosonics UCR100 has a TRS (Tip-Ring-Sleeve) mini-jack output and it is a BALANCED output.
