outdoor mix?
Peter Ralph
outdoor mix?
on Nov 17, 2005 at 9:23:30 pm
is there some EQ tweaking that I can use so a CD track sounds like it was recorded from a sound system out of doors?
Frank Nolan
Re: outdoor mix?
on Nov 21, 2005 at 8:44:26 am
That depends on what sort of recording you are trying to make it sound like. Is it a music track, a dialogue track or...? Do you want it to sound like it was recorded off a megaphone type P.A. system like at a race track or off a concert P.A. system? To answer your question as it is....yes! but without really knowing what you are trying to achieve and what your source material sounds like now it's pretty hard to give any sound advice!
Peter Ralph
Re: outdoor mix?
on Nov 22, 2005 at 1:02:46 am
just regular music tracks from CDs that were played through a soundsystem outside. I have the CDs but other than adding sound effects have not been successful in making them sound as if they were recorded outside.
Frank Nolan
Re: outdoor mix?
on Nov 22, 2005 at 7:39:00 am
Your answer is still a bit vague but try adding a slap back delay of about 80-100ms with a short decay. Then roll off the low end below 150hz and the high end above 10k and see if that gets you in the ballpark.
