Most efficient way to burn 11 x 90min clips onto 80min CDs
Chris Huggett
on Aug 23, 2005 at 11:09:35 am
Hi guys
I have been asked by a friend to put 11 audio cassette tapes onto CD.
So using Sound Forge 7, i have recorded the clips, used the vinyl restore to take out alot of the hiss/noise. I can only get hold of blank CDs that hold 80 mins of audio.
So what would be the best way to put these 11 clips onto CD?
Thanks for any suggestions
Chris
Seth Bloombaum
Re: Most efficient way to burn 11 x 90min clips onto 80min CDs
on Aug 23, 2005 at 3:04:08 pm
If you're going for audio cds that play in any standard player then your only choice is to cut them up into 80 (or maybe 78) minute segments. It's a standard, you can't push and shove on it UNLESS you're going for the class of players that will let you play MP3s on a CDR. Then you've got lots of room on the disc.
David Jones
on Aug 23, 2005 at 6:04:39 pm
Your other choice would be to go the the DVD format if the client has a DVD player.
