Wind noise frequency & how to reduce in post
Jim Watt
on Jul 3, 2005 at 5:12:17 pm
We have a dialogue sequence in HD, with a crabber, there's boat noise and some wind noise, which I'd like to reduce. What's the best way to find the wind noise frequency to hopefully make it less objectionable. For tools, I'm working with FCP 5 and Sound track Pro.
thx..jw
David Jones
Re: Wind noise frequency & how to reduce in post
on Jul 3, 2005 at 7:33:15 pm
High pass filter.
Jim Watt
on Jul 3, 2005 at 11:42:28 pm
Thanks, but any suggestions on where to start with the settings?
thx..jw
Peter Perry
on Jul 4, 2005 at 1:09:38 am
Hey Jim,
Wind is very difficult to deal with because it isn't happening in one freq or band of freq's....it is very broadband and is constantly changing. and because of that, what you do to minimize wind noise will probably affect dialogue also.
Without hearing the sound, nobody can give you settings to start with. Try using a parametric EQ with a sweepable frequency control. Use the boost/cut control to drop the level 5 dB or so, then sweep the freq control through the selected range, and if you find someething that helps, adjust the bandwidth settings so that you affect the desired sounds as little as possible. Don't expect big improvements, you're kinda stuck. You could also try noise reduction software if you can get a long enough sample to use.
Peter
JRF
by
on Jul 4, 2005 at 10:56:54 pm
If you use ST Pro or a program like Sound Soap Pro, instead of trying to find a noise reduction setting that works for the entire clip, cut the clip into pieces. Cut the pieces so the sound you're trying to remove stays the same throughout the clip. You have a better chance of removing the bkg sound that way since it is more constant. After doing that (it can be very time consuming) you might want to add some bkg noise back in to mask the clip-to-clip changes in bkg sound in the processed clips.
John
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Dual Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
Bob Cole
on Jul 15, 2005 at 6:55:15 pm
If the wind is visually part of the scene, that would make it more acceptable as part of the sound track.
-- BC
