XL1 & Yamaha EMX68s
PAO
XL1 & Yamaha EMX68s
by
on Apr 27, 2005 at 1:35:52 pm
I have never connected my camera to a mixer or house sound system before. In agreeing to do a friend a favor (on very short notice), I now find myself shooting a bluegrass performance this Friday. He has a Yamaha EMX 68s mixer and I am clueless how to connect to it, but I'm ready to learn. I tried to connect from the mixer via the REC OUT with an RCA cable to my XL1, and it sounded terrible. It was way too loud and garbled. I adjusted the level down, but the sound quality was still bad. I reread the XL1 manuel, tried various options, but I must be missing a setting somewhere. I would appreciate suggestions to make this work. I am willing to purchase the proper cable to make the right connection, I just am clueless where to start. Thanks in advance for your help. Pat
JRF
Re: XL1 & Yamaha EMX68s
by
on Apr 27, 2005 at 7:16:30 pm
There are two things I can think of that can be causing the distortion you are hearing. The first is that the line level being sent from the mixer is overloading the input preamp of your camera. Adjusting the level controls on your camera won't fix this. You need to lower the level coming out of the mixer. You can do this by adjusting the "Sends" on the mixer. If this is not possible, you need to use a "pad" that will attenuate the level. A pad looks like a tube with a connector on each end. You plug one cable from the mixer output into one side of the pad and a cable to the camera into the other side of the pad. You'll need two pads as they are typically mono devices. Usually pads are switchable so you can pick an amount of attenuation that eliminates the distorsion, but doesn't make the level too low, ie. -10 or -20db. The second thing you need to check is that the cables running from the mixer to camera are wired correctly. You mentioned RCA connectors. Are the outs on the mixer and the inputs on the camera both RCA? If so, then the problem is most likely the output level being too high. If one end is RCA (2 connections: center and shield) and the other is XLR (three connections: high, low and shield) you must make sure the cable is wired correctly. If the cable's not wire correctly you'd hear tinny and/or hum-filled audio, probably not distorsion. Hope this helps.
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
PAO
by
on Apr 28, 2005 at 3:57:56 pm
Thanks for your response! This gives me a place to start and I appreciate it. Pat
