Flickering artifact on right hand side of exported content
Tim Jones
on Oct 9, 2017 at 9:59:06 am
I have an issue where exports from Premiere (CC 2017.1.2 on OS X High Sierra) have a flickering artifact on the right hand side.
The footage was created on a Canon C300 MkII, and ingested into Prelude (CC 2017.1.2 on OS X High Sierra) with NO transcoding.
Footage underwent a bit of basic stuff (timeline cutting, grading etc).
Playback in Premiere is perfect, NO flickering artifact.
I then go Premiere -> Export Media.
"Source" shows as "4096x2160(1.0), 25fps, Progressive, 48kHz, Stereo".
I have tried "Format H.264, Preset Match Source - High Bitrate" preset (which shows "Output" 4096x2160(1.0), 25fps, Progressive, 48kHz, Stereo") and this yields green flickering on the right hand side.
I have tried the "H.264 YouTube 2160p 4K" preset which shows output (which shows "Output" 4096x2160(1.0), 25fps, Progressive, 48kHz, Stereo") and this yields black flickering on the right hand side.
I have tried exporting using "maximum render quality", this makes no difference.
I have uploaded a short screen capture video to show what I mean:
https://vimeo.com/237375317
James Culbertson
Re: Flickering artifact on right hand side of exported content
on Oct 10, 2017 at 6:16:03 pm
A friend has the same issue (with same camera footage) but only with proxies, and not with the source itself. He is seeing it both in playback of the proxies in Premiere and on export of the proxies. I've been trying to help him but cannot duplicate the issue on my machine with the same up to date versions of Premiere and AME. Was going to post here, but hope someone can suggest a solution to your issue.
Tim Jones
on Oct 10, 2017 at 8:50:48 pm
Thanks for the words of support James !
I've posted the same question over on the Adobe Premiere forums too, but no bites on that line either. ;-(
So at the moment I'm just stuck with a bunch of files, nicely edited and ready to go and pretty much left to twiddling my thumbs having experimented (in a controlled manner) with every config parameter I could think of.
I don't think its a hardware problem with the C300 used, because I've had no problems with a couple of 1k clips shot on the same camera before 4k was enabled.
Its just weird. I'm starting to think perhaps its not me but some weird bug ? But then surely someone else either here or on the Adobe forum would have already piped up "yeah, I've seen that one".
Tim Jones
on Oct 11, 2017 at 5:34:50 pm
James (and fellow forum members 😎)
I have had a bite on the line I left dangling in the Adobe forums.
The suggestion was to change engine from OpenGL to something else.
I switched from OpenGL to Metal and the flickering disappeared.
Which I'm obviously happy about because I can finally complete my work. YAY ! 😄
But it does leave me with a problem in that Metal is obviously slower to render than OpenGL.
Plus surely OpenGL should be supported on the Radeon chipsets (Radeon Pro 560 4 GB) that feature in the latest MacBook Pro's ?
James Culbertson
on Oct 13, 2017 at 3:12:05 am
[Tim Jones] "I switched from OpenGL to Metal and the flickering disappeared."
Didn't work for my friend. I'll have him try software only to see if that helps. He has a MacBookPro, but not sure yet which graphic card.
I have the D700s in my Mac Pro and have no issues.
Dan Powers
on Oct 12, 2017 at 3:32:35 pm
Would you by chance have a D500 Video card on a Mac Pro?
I have random flickering of supers unless I turn off hardware acceleration. You may try that and see if it goes away. I believe it to be a GPU error. Apple denies the problem exists. Says it is adobe. Adobe says it is the GPU which I do tend to agree.
Tim Jones
on Oct 13, 2017 at 12:00:42 pm
Adobe support is about as useful as a fart in a bathtub.
I tried approaching them about this problem.
Got absolutely nowhere other than going round in circles of random guesses with someone based in "that part of the world where customer service goes to die".
David Seay
on Jan 31, 2018 at 2:02:41 pm
I just had the same exact issue. I solved it by changing the render engine from Metal to OpenGL. You might also try using the Software Only mode as well, it's slower, but doesn't use your GPU.
Hope this helps
TV- It's why Kennedy beat Nixon
david seay
http://www.davidseayproductions.com
James Culbertson
on Feb 1, 2018 at 1:44:28 am
[David Seay] "...changing the render engine from Metal to OpenGL. You might also try using the Software Only mode as well, it's slower, but doesn't use your GPU."
Yes, we tried both of those things, but not go. In the end, it took using a still to cover the side to fix the proxy renders for review. Final output was fine.
Iancu Ilies
on Jun 30, 2018 at 5:20:59 pm
I found out a workaround that removes the flickering and the black pixel on the right side. Increase the scale of your video footage to 100,5 and the export will be perfect. It's an Adobe/Apple bug, the software cannot understand 4k (4096) footage, pixels are either not counted properly or some other size or scale related issue. Ridiculous... I am considering switching to Davinci Resolve for cutting as well, after many years of Premiere Pro. The downside of Premiere began when they removed Speedgrade. In my humble opinion Adobe will disappear in 10 years from now and will be irrelevant in 5.
alex robertson
on Jun 6, 2018 at 2:45:00 pm
I have this same issue. Working on 4k mov files in premiere, then exporting as the same, 4k movs.
Everything seems fine until we review the new export movs. Black flickering vertical line on rightmost edge of video. It is only a couple of pixels' diameter, right on the edge.
Following forum suggestions I have tried all three graphics options in Premiere -setting video renderer to OpenCL; Metal ; Software only, in project settings. Exactly same result each time.
Further thing I noticed: For my batch, the flicker only occurs on clips whose speed I have altered in the timeline:
I exported 5 clips separately.
2 of them I left as shot (59.94fps on a 29.976 project, so 50% of 'realtime' speed) - no flicker, perfect exports.
The other 3 I sped up slightly - they have flickering line.
This is not a solution, but perhaps will help developers track down and identify the bug? Squash it, please!
alex robertson
on Jun 14, 2018 at 12:17:22 pm
My (not so cheap) solution has been to plug in an extra graphics card via an eGPU (Sonnet eGFX with a Radeon RX580)
The flicker has disappeared. The moment I remove the graphics card and export the same clips, the flicker returns.
WTF is going on behind the scenes I have no idea, but there is my workaround. Adobe please pull your socks up
alex robertson
on Oct 23, 2018 at 11:44:52 am
This is still happening.
Unfortunately, I appear to have spoken too soon in my last post. Even with my eGPU plugged in (and I have upgraded since my last post to a Radeon Vega 64), the flicker line is still there whenever I alter the frame rate on the timeline.
It's absolutely maddening. If I slightly change the speed/duration of a clip, or ramp the speed in any direction, I get the flickering black line when I output.
That is, to put it lightly, quite a restriction when editing.
WTF? Can someone from Adobe comment on this please?
Jack McGovern
on Jan 8, 2019 at 5:04:46 pm
I know this is an old post, but what graphics card do you have installed on the computer that is causing you this issue? Is it a NVIDIA GT 750M by chance?
