Auto adjust fluctuating gain levels.
Eric Merklein
on Sep 28, 2017 at 8:28:10 pm
I have a first time problem.
There is a scene where auto iris is fluctuating as the talent moves his hands in front of his bright shirt.
Is there a magical plug in or a Premiere pro effect that can smooth out these fluctuations. If not, I may have to alter color correction and throw in a dissolve.
Thanks much.
Chris Wright
Re: Auto adjust fluctuating gain levels.
on Sep 29, 2017 at 1:17:16 am
if it only happens a few times, crossdissolving the adjustment layer color correction is the fastest.
if it happens like 50 times, you could try a free auto remove flicker and auto white balance after effects template. works so well, I haven't changed the code in years.
https://forums.adobe.com/thread/2265617
also, if you need a professional plugin, there's many to choose from:
these work in premiere:
http://www.granitebaysoftware.com/products/productgbd.aspx
http://www.digitalanarchy.com/Flicker/main.html
http://www.revisionfx.com/products/deflicker/
Eric Merklein
on Sep 29, 2017 at 2:31:50 pm
Thanks Chris. I'll give the plug-ins a try. I'm great at mixing 16 tracks of audio and color correcting, but I'm not an After Effects Head
