Full Screen Preview on Primary Display Drops Frames
Matt Hale
on Sep 26, 2017 at 11:46:06 pm
I have a strangely specific issue with Premiere CC 2017 (v11.1.2 (22) Build).
I have two monitors hooked up to my graphics card (GTX 970). Both monitors are 1080p Samsung televisions. One is a 32-inch connected using a DVI > HDMI cable and one is a 55-inch connected using HDMI. The 32-inch is set to be my primary monitor. The 55-inch is across the room from my desk and I use it mostly as a client monitor, so people can sit on the couch and watch on the big screen as I drive from my desk.
When I have the 55-inch monitor set up as a video device (Preferences > Playback > Video Device), full screen video from all kinds of sources plays like butter (h.264, ProRes/DNx, RED, etc. all play without issues)--even 4K at full res plays just fine with no dropped frames at all (dropped frame indicator stays green 99% of the time).
However, when I try to play video full screen on my primary monitor (the 32-inch) using control-tilde, I get constant dropped frames. And, again, it doesn't matter what the source is. Even low res proxy files drop frames like crazy.
Note: I always disable the second display in Preferences > Playback > Video Device before attempting this. In fact, it doesn't even matter if I physically disconnect the second monitor from the system. I've also tried switching the primary monitor from the DVI connection to the same HDMI connection that I normally use for the client monitor and the problem persists.
I've tried moving media to different drives (from USB 3.0 drives, to internal spinning disks, to my SSD); I've also made a fresh project, imported just a single clip, and made a new sequence using the "New Sequence from Clip" option and the behavior is the same.
I don't think this has anything to do with codecs or drives because (a) everything plays fine on my second monitor so it's clear my hardware can handle playing this media full screen, and (b) the problem repeats with all kinds of media on many different drives.
Also note: Everything also plays just fine on my primary monitor using any windowed configuration. If I select my Source or Program monitor and hit tilde to maximize the window, I do not get dropped frames. Even if I have the resolution set to Full and the Zoom Level set to 100%.
The dropped frames only happen when I'm in full screen mode (control-tilde) on my primary monitor.
Other stuff I've tried:
- Checking and unchecking "Adobe DV" in Preferences > Playback > Video Device
- Checking and unchecking my primary monitor in Preferences > Playback > Video Device
- Checking and unchecking "Enable Mercury Transit" in Preferences > Playback
- Switching between CUDA, OpenCL, and Software Only in Project Settings > Video Rendering and Playback
- Emptying out the Media Cache folders
- I've restarted the machine many times
The dropped frames persist, but, again, only in this one specific scenario of attempting to play clips full screen (in either my Source or Program monitor--it doesn't make a difference) on my primary display. Since the other monitor is across the room, this function is extremely useful to me--maximizing the window is no substitute for full screen.
I'm at a loss! This really feels like a bug to me. Has anybody ever run into this issue? Any troubleshooting ideas?
My system:
Hackintosh running OSX 10.11.6
Intel i7-4790K
32 gigs RAM
GTX 970 GPU with 4 gigs of vram
Adobe Premiere 11.1.2 (22) Build
andy patterson
Re: Full Screen Preview on Primary Display Drops Frames
on Sep 27, 2017 at 6:04:25 am
It might be a bug. I output to a BMD Intensity Shuttle.
Marek Fiasko
on Oct 2, 2018 at 10:05:02 pm
I have bad news for you.
I found this thread looking for the same issue and apparently it has something to do with hardware. I have exact same machine with the same OS build and have the same problem. I have tested various Premiere versions and still get the same effect: when I go full screen it starts to drop frames.
I think it has something to do with graphic card. Before i had gtx 660 card and everything worked normally. I upgraded to gtx 970 and now it works faster with most applications but I noticed the problem with premiere. I also have another issue - when starting computer with 2 monitors connected - sometimes it loads system in the first try, sometimes it restarts over and over again until system is loaded. It usually needs 1-4 tries. The guy who have built my machine suggested that gtx 970 is a newer cards and thats why it can have issues with older OS version. Maybe upgrading OS would help?
If you have found the solution meanwhile, let me know ☺
Cheers
greg janza
on Oct 2, 2018 at 10:29:01 pm
I have the GTX970 in a dual monitor setup but I'm outputting my main image through a Blackmagic 4k mini-monitor so I haven't encountered this. My first step would be to make sure all drivers are up to date:
https://www.geforce.com/drivers
Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2018 12.1.2 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
