Media Encoder dropping LUTs on export
Jack Savage
on Sep 26, 2017 at 2:00:11 pm
I have a 4K timeline using the S-Log 3 LUT and some other minor color corrections, and when I send it over to Media Encoder the LUT is being dropped and the final video looks just like it did coming straight out of the camera.
Has anyone else experienced this issue? And what was the fix?
Andy Edwards
Re: Media Encoder dropping LUTs on export
on Sep 26, 2017 at 7:47:46 pm
If on a Mac, try copying your custom S-Log 3 LUT to the Media Encoder / Contents / Lumetri / LUTS folder. Go to Applications and Right click on the Media Encoder icon, show contents, then path to the folder and paste your LUT. Media Encoder should now see your LUT when exporting. Be careful doing it this way as some custom LUTs are not supported and can lead to odd behavior with your Adobe applications.
Additionally, you can add your S-Log 3 LUT through the effects tab of Media Encoder's export preset setting so it points to the LUT properly.
other links you can read:
https://www.premiumbeat.com/blog/adding-luts-in-premiere-pro/
https://forums.adobe.com/thread/2299049
Andy Edwards
Desmond Sukotjo
on Apr 12, 2018 at 12:49:14 am
Hi. Are you able to select your own LUT in Adobe Media Encoder setting under Effect tab? When I do that (just like your screenshot on your post), I choose select, nothing happen.
