Artifacts on upper edge of preview screen
Juan Carreras
on Sep 19, 2017 at 7:22:59 pm
I have an annoying problem happening across many projects: my preview screen often displays a band of artifacts across the upper edge about 2-3 pixels wide when the preview plays (see attached). It seems to happen in the clips with video and not when I add a blank frame with titles for example. Sometimes it disapears if I resize slightly the frame size but it re-appears when I render the video previews. Fortunately, it doesn't affect the final output but it's nevertheless annoying .
I'm using PPCC v7.22
Any suggestions ? - Thanks
11701_artifacts.mp4.zip
jerry wise
Re: Artifacts on upper edge of preview screen
on Sep 20, 2017 at 7:31:16 pm
you can get that if you speed up or slow down footage. i usually just up-size it a bit.
Juan Carreras
on Sep 20, 2017 at 7:40:35 pm
None of the clips are changed in speed, they are actually image sequences.
Sometimes I've resized them up a bit as you suggested but since the artifacts don't appear in the final output, I don't bother anymore but I was hoping that there was a proper solution without having to resize. For what I gather, it's a fairly common bug that has not been fixed.
Ann Bens
on Sep 21, 2017 at 10:52:32 am
Might want to update to 11.1.2.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Eric Merklein
on Sep 21, 2017 at 2:25:51 pm
Hello Ann.
Is version 11.1.2 available? I was in Cloud yesterday and didn't see any updates for Pro?
Thanks much.
Eric
