Update without removing previous versions PP CC2017?
Walter Stabb
on Sep 19, 2017 at 9:01:34 am
Hi all,
Quick question. Previously when updating Premiere Pro app there was the possibility, through the advanced menu of the update window, to untick the default remove previous versions. Is a similar function available in the current version of CC (which doesn't seem to feature an Update window)?
I am aware of the process to install previous versions, which clearly provides a work around but would rather just install new versions parallel to the previous.
