Adobe Premiere Pro CC 2017: No video !
charles beny
on Sep 13, 2017 at 2:00:22 pm
Hello America, Hello the world
I'm a french dude, big fan of David Blaine and I would like to start editing some of my street magic videos.
Here is the problem :
All the videos I use come from an iPhone 6s (.Mov)
When I create a sequence, i can hear the sound but i don't have the image, no matter what i do.
It seems that the whole problem is due to a codec issue: I actually can not find H264 pre-config in the settings of my version of Adobe Premiere pro CC 2017.
How can I get this H264 setting ?
Are there any other possible cause ?
Some info:
TOSHIBA Qosmio x870
Intel (R) core i7-3630QM CPU @ 2.4GHz
8 Go
System: 64 bits
My pilots and both Premiere pro and Adobe reader are up to date.
Don't hesitate to ask me anything that could be relevent for you guys to help me
Thanks so much for reading
Have a great day
Beny-eng
Ann Bens
Re: Adobe Premiere Pro CC 2017: No video !
on Sep 13, 2017 at 3:53:23 pm
Might want to install just the QT codec not the player.
If your footage is variable framerate Premiere cannot handle this.
Convert to constant framerate with Handbrake before bringing it into Premiere.
http://handbrake.fr/
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
charles beny
on Sep 13, 2017 at 6:51:35 pm
Thank you cow boys
I shot with DJI GO APP that, I believe, implies a constant frame rate
Here is the analysis of one of my footage using mediainfo:
General
Complete name : C:\Users\benyc_000\Documents\himitsu no shimei\Captures\CHATELET 0209 1\DJI_0006.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2014.02 (qt )
File size : 47.2 MiB
Duration : 6 s 590 ms
Overall bit rate mode : Variable
Overall bit rate : 60.1 Mb/s
Encoded date : UTC 2017-09-02 18:06:59
Tagged date : UTC 2017-09-02 18:06:59
Comment : 0.9.138
©gpt : +177.20
©gyw : -11.20
©grl : +0.00
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 60.0 Mb/s
Maximum bit rate : 50.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.483
Stream size : 47.1 MiB (100%)
Title : DJI.AVC
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : mp4a-40-2
Duration : 6 s 571 ms
Bit rate mode : Constant
Bit rate : 64.1 kb/s
Nominal bit rate : 128 kb/s
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 51.4 KiB (0%)
Title : DJI.AAC
Language : English
I will try asap your technique Ann Bens. Thank you
Keep in touch
Bret Hampton
on Sep 14, 2017 at 12:45:44 am
Salut Charles
Est-ce vous pouvez nous donnez des exemples de vos videos ? C'est plus simple de repondez avec des bonnes suggestions pour utilizer.
