Premier pro crashing on timeline playback
John Crack
on Sep 9, 2017 at 5:51:38 pm
This has never happened but I used the trial no issues, until the last day. The issue is I open up a project (ive tried it through numerous new projects now), and try to play the media in the timeline and the program freezes then crashes. It scrubs fine but the second I hit play it just freezes then says "not responding". The other strange thing that occurs is when I startup premier, it does seem to take a little bit longer to load, but there is no video playing in the background of the main menu like there usually is. After everything freezes and locks up I have to force quit it from the task manager. As I can tell everything seems to work perfectly fine until it comes to playback.
Computer Info
OS - Win 10
Processor - Intel i7 7700HQ @ 2.8ghz
System Type - x64 operating system and processor
Memory - 16gb
Graphics Card - GeForce gtx 1050 (version 382.05)
Project Info
Premier  Pro CC 2017 11.1.2 (22) build
1080p 29.97 footage (3840 tried as well), clips no longer than a minute themselves
Timeline total, less than 3 minutes of footage
Production and audio files are on same ssd
Project size: 50mb
Failed Fixes
Disabling firewall to allow premier to make connections
Reinstalling premier multiple times
Reinstalling windows
Updating all drivers
Trying different media files
Opening new and different projects
Dave LaRonde
Re: Premier pro crashing on timeline playback
on Sep 10, 2017 at 12:41:54 am
Your post leads me to believe the tryout period has expired. Is this correct?
Dave LaRonde
Promotion Producer
John Crack
on Sep 10, 2017 at 3:57:46 am
Correct. However this started occuring 2 days before the trial ended. I since have licensed the software.
Tony Rose
on Oct 11, 2017 at 2:53:01 am
Have you found a solution to this issue? I've been having the same problem.
I'm wondering if it has something to do with CUDA or Mercury Transmit as we both have nVidia cards.
