Trouble playing DPX sequences
Bret Hampton
on Sep 6, 2017 at 5:46:58 pm
Hi gang
My computer plays almost everything at full resolution with Mercury playback except for dpx sequences. I prefer full rez as I do film restoration and anything less obscures the very things I need to fix.
HP Z800 dual Xeon processors 6 cores each
24g ram
SSD boot drive
NVIDIA GTX 870 GPU
G-Tech G Speed ES w/their controller
PP CC current version.
Tero Ahlfors
Re: Trouble playing DPX sequences
on Sep 6, 2017 at 5:58:38 pm
With DPX sequences your storage media needs to be fast. How big DPX frames are you trying to run at what frame rate? How fast is your storage?
Bret Hampton
on Sep 6, 2017 at 8:58:17 pm
Hi Tero
Am using G Tech Gspeed es in Raid 0, all Enterprise class 7200 rpm drives. DPX files are 2336x1752 16m each at 23.98. (These are 4x3/1.33 film scans of a 1928 movie.
Tero Ahlfors
on Sep 7, 2017 at 3:56:45 am
[Bret Hampton] "Am using G Tech Gspeed es in Raid 0, all Enterprise class 7200 rpm drives."
But how fast is it? You would need at least 400 MB/s and the official specs say that it can run up to 252 MB/s. Which is not enough.
Bret Hampton
on Sep 7, 2017 at 3:24:58 pm
Thanks Tero
That was the information I needed but couldn't remember. As configured my system isn't fast enough. Do you play dpx files? What drive setup could handle this?
