Premiere will only let me play from in-point to out-point
Anne Colton
on Aug 23, 2017 at 12:52:22 pm
I have in and out points set on my source clip, but I would like to jump earlier just to check what's before my in-point. When I hit the space bar, the payback will only start at my in-point. The only way to play back something from earlier in the clip is to clear the edit points. Is there a way to make it play back anywhere on the clip, regardless of edit points?
Ann Bens
Re: Premiere will only let me play from in-point to out-point
on Aug 23, 2017 at 1:14:12 pm
Space bar should not play in to out, Enter should.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Anne Colton
on Aug 23, 2017 at 1:19:32 pm
Agreed. But it's not doing that right now. Space bar is only going in to out. Another editor was working on my system, so he might have changed something, but I have no way of contacting him. Is there a way to fix it? I feel like it must just be a box that needs to be checked...
Anne Colton
on Aug 23, 2017 at 1:45:17 pm
Never mind, I figured it out... on the source window, under the WRENCH icon, there's a setting called LOOP. I unchecked it, and all is well again. Thanks!
Jeff Hight
on Oct 31, 2018 at 6:20:51 pm
Even though you figured this out on your own, I thank you because this was just messing with my head why space bar kept doing in-out. Thanks again!!
Carolyn Lecorre
on Feb 8, 2019 at 8:37:53 pm
Thank you! I started working at a new place and tried to remap over and over again the keyboard (it was mapped correctly in the first place). I didn't know about that Loop option.
Those little things cause or save lots of grief
