Ppro and Audition time code issue
Herb Sevush
on Aug 18, 2017 at 1:30:08 pm
When sending a clip over to Audition for repair work the reference file always comes back as Non-Drop Frame TC, which is strange since I'm always working in Drop Frame. In order to get the TC to match properly I have to go into modify clip properties and manually set the TC back to Drop. Is there some preference setting in either Audition or Ppro that will get it to send back the same type of TC I started with? This is an amazingly annoying PITA in what is otherwise a wonderful feature of Ppro.
By the way I'm working with the latest release of PPro and Audition, on a Mac Pro and cutting ProRes 1080P30.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
Dave LaRonde
Re: Ppro and Audition time code issue
on Aug 18, 2017 at 5:58:56 pm
I couldn't find any settings for time code in Audition. You might have to export from Audition using Adobe Media Encoder... which you can do.
Dave LaRonde
Promotion Producer
Herb Sevush
on Aug 18, 2017 at 6:12:31 pm
Dave -
Exporting using AME is even more cumbersome than re-setting the TC in Ppro. Roundtripping between Ppro and Audition has been a huge productivity gain for me in dealing with audio, it's just this one stupid thing that makes it harder than necessary and I was hoping I was just missing some setting somewhere. If not I'll have to start whining about this to Adobe and see if they can't fix it.
Herb Sevush
Zebra Productions
