Colour grading / S-log footage - Workflow
Joao Pereira
on Aug 15, 2017 at 10:50:25 am
Hi everyone,
I receive a lot of rushes shot in s-log2 and s-log3. I'm very far from an expert in colour, etc, but sometimes the client requires a short turnaround and I've been using Lumetri in Premiere most of the times. However, I'm still searching for a more fluid and quick workflow which can deliver good results. Most of the footage is shot for web content and I'm only looking for standard natural looking colours.
I have tried downloading different LUT's to grade the footage as rec709 and have a good reference or a starting point but none of them seem to do it properly. The results are always very off after applying the LUT. . I'm probably doing something wrong and would like to know your input.
What's your workflow to grade Slog footage with Lumetri?
Cheers,
Chris Wright
Re: Colour grading / S-log footage - Workflow
on Aug 15, 2017 at 11:29:42 am
you could make a lut in lumetri, export it as 1_yourfile and it will pop up at the top dropdown menu.
or you could try my free effect preset which works as 32bpc( 0 precision loss) effect which simply normalizes what you recorded.
free slog 3 to rec709 effects preset for premiere.
create a vibrant film look from slog3 footage without speedgrade or any luts!
a tweakable effects preset that can be modified to work for slog2 or any other flat look in only a few seconds.
how does it work? it uses fast color corrector as a pre-contraster limiter for brightness/contrast filter.
Simply edit fast color corrector input white black and output white black. drag effect onto footage or adjustment layer.
https://f1.creativecow.net/file.php?id=9975&folder=slog-3-to-rec709-effects...
-the fastest turnaround would be to make each clip look the same first, then apply one adjustment layer to all clips for color.
https://forums.adobe.com/thread/2117929
-make your own lumetri lut
https://forums.adobe.com/thread/2211190
greg janza
on Aug 15, 2017 at 4:24:21 pm
I work with slog3 footage regularly and my normal workflow is to add a kodak lut (5203 NEG) to all of the footage. I've also used filmconvert in the past and that works well too.
the key to adding these LUTS to a timeline is being able to make use of the Mercury Playback engine (CUDA). this allows for easy playback and faster rendering.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
Joao Pereira
on Aug 16, 2017 at 8:54:35 am
Thank you very much Greg.
I'll give it a try.
Cheers,
Joao Pereira
on Aug 16, 2017 at 9:22:40 am
And thank you Chris. I'm giving it a try to your preset now.
Cheers,
Cheers,
João Pereira
Neil Kendall
on Mar 14, 2018 at 1:32:17 pm
Hi Chris,
Thanks a lot for sharing your slog 3 to rec709 effects preset for Premiere. I'm trying to use it on a Mac, but to no avail. Do you have any tips for importing in to Prem?
Many thanks,
Neil.
