Weird Premiere CC behavior when saving, opening window, etc (11.0)
Bill Hilferty
on Aug 9, 2017 at 6:01:07 pm
Hello there, On my PC systems premiere does a weird time wasting thing whenever I open a marker note window, or save the project. See the video below. The project panel seems to ripple through all of the clips or something before an action completes. If I close my open bins and reduce the amount of items taking up space in the project window it is Alot quicker. Anyone know why this is happening and if I can get it to stop?
Win 10 64 bit
16 gigs ram
gtx 1080
i7 7700k 4.5 ghz
Premiere Pro CC 11.0
Thank you
Eric Merklein
Re: Weird Premiere CC behavior when saving, opening window, etc (11.0)
on Aug 9, 2017 at 6:47:41 pm
Have you checked out RAM to make sure it's all good? I run at 32 gigs which might help.
Eric
Many thanks.
Bill Hilferty
on Aug 10, 2017 at 12:47:23 am
I have another windows pc running 64 gb, basically an identical system except a locked processor and gtx 1070 vs 1080. Could if be a graphics card issue?
Todd Perchert
on Aug 10, 2017 at 8:27:08 pm
Not sure why it's happening. Couple things to try.
Try another keyboard - which if it's doing it when opening other bins, then I doubt this will help.
Try blowing out your preferences.
To restore default preference settings and plug-in cache at the same time, hold down Shift-Alt (Windows) or Shift-Option (Mac OS) while the application is starting. Release the Shift-Alt keys or Shift-Option key when the splash screen appears.
https://helpx.adobe.com/premiere-pro/using/preferences.html
Let us know if anything works, or doesn't.
Good Luck!
TC
Bill Hilferty
on Aug 11, 2017 at 12:58:47 am
Thanks for the response but none of that helped.. Weird. On my less powerful mac it actually seems to run faster overall... Project loads the 5,000 items in a flash on my macbook pro but it takes up to 3 mins to load them on my PC with better specs. And then that thing in the video. Any other ideas!??
