Red Giant Denoiser III broken under latest version of Windows
James Kumorek
on Aug 2, 2017 at 12:26:49 pm
For anyone who cares, when my editing PC updated to the latest version of Windows 10 this week, Red Giant Denoiser III stopped working in Premiere. Any frame that has Denoiser III active won't render as you edit, and if you start a render of the timeline, the render gets stuck at the first frame with Denoiser III active. Reverting to the previous version of Windows 10 fixed the problem.
Tero Ahlfors
Re: Red Giant Denoiser III broken under latest version of Windows
on Aug 2, 2017 at 12:31:19 pm
Are there any updates available for the plugin?
Duke Sweden
on Aug 2, 2017 at 5:50:07 pm
I don't remember being notified that Windows 10 updated recently but after reading your post I tried applying Denoiser III to a video clip. Well, Premiere Pro crashed in the weirdest way. I could still turn Denoiser on and off, delete it, add another plugin, but none of them actually affected the video, and the video stayed frozen, even after I deleted Denoiser. I actually had to reboot to get PPro to act normal again.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0
Ann Bens
on Aug 2, 2017 at 9:26:17 pm
Found this for a previous update: replace 7.0 by 11.0, might work.
-Close Premiere
-Move all folders from "C:/ProgramFiles/Adobe/Common/Plug-ins/7.0/MediaCore" to another location
-Start Premiere with "Shift" held down to clear out plugin cache/registry
-Put back one of the plugin folders and try to start Premiere again
-Repeat for each folder
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
John Mayer
on Aug 9, 2017 at 5:18:46 pm
I think this trick worked for me. Didn't had to rename to 11.0 tho.
