photoshop layers and premiere pro
kerry baldry
on Jul 31, 2017 at 10:39:41 am
Hi, I am trying to import photoshop cc layers to premiere pro cc (2017)
but once imported into premiere pro the images turn to black.
jpegs etc are all ok.
Jon Doughtie
Re: photoshop layers and premiere pro
on Jul 31, 2017 at 8:41:30 pm
Do you have any Photoshop effects applied to any layers? I don't believe those will translate in Premiere Pro.
Do you have any layers/elements/files that are not 8-bit RGB? If you have, for example, and elements with a CMYK colorspace, they won't make the transition.
These are the first two things I would check.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
kerry baldry
on Aug 1, 2017 at 6:45:42 am
Hi, thanks i checked - the image is 8 bit and RGB. There are no effects applied to layers. Still comes out
black in premiere..
Ann Bens
on Aug 1, 2017 at 7:50:21 pm
What are your sequence settings and what are the dimensions of this psd file?
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
kerry baldry
on Aug 2, 2017 at 8:15:14 am
Hi
When I go into premiere pro cc
into New: New photoshop file
a file with the same settings (whatever settings i have chosen) is automatically
made in photoshop. However the although the two are linked the image in premiere pro is black.
