Black line in the bottom of the video (MJPEG codec)
Marina Cotrim
on Jul 27, 2017 at 2:47:33 pm
Hello everyone,
I'm trying to edit a video in Premiere CC, but when I view it in the monitors, there is a black line of 1 px height in the bottom of the image. When I scale de image, the line goes away.
What is weird is that when I view the same video on VLC, there is no black line.
I would appreciate any toughts that might help me getting rid of this line (without the scaling).
Media Info:
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 2.20 GiB
Duration : 5mn 58s
Overall bit rate : 52.7 Mbps
Writing library : Livestream Avi file writer
Video
Format : JPEG
Codec ID : MJPG
Duration : 5mn 58s
Bit rate : 51.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Original height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.824
Time code of first frame : 11:44:57:00 / 11:44:57:00
Time code source : Adobe tc_A / Adobe tc_O
Stream size : 2.14 GiB (97%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 5mn 58s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 65.7 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 33 ms
Thank you!
Ann Bens
Re: Black line in the bottom of the video (MJPEG codec)
on Jul 28, 2017 at 1:46:14 pm
Does it show on export?
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Marina Cotrim
on Jul 28, 2017 at 2:39:24 pm
Hi, Ann,
Yes, it does...
Ann Bens
on Jul 28, 2017 at 5:48:43 pm
might be a codec issue.
Just scale it up one pixel.
