Bulk removing / disabling effect
Marc Nibor
on Jul 24, 2017 at 11:45:26 am
I have a quite complex project with around roughly 600 snippets. Each one of them has the "Clip Name" effect activated. Soon I will start rendering the Final Cut... and I am looking for a simple workaround that allows me to quickly disable/remove the effect on every single snippet.
Any ideas? Thank you.
Simon Ubsdell
Re: Bulk removing / disabling effect
on Jul 24, 2017 at 1:02:16 pm
Select all your clips and either right-click and select Remove Attributes or select it from the Edit menu.
You can then choose which attributes to remove, in your case make sure Clip Name is selected. Make sure to uncheck any effects etc. that you don't want to remove.
Simon Ubsdell
tokyo productions
hawaiki
Marc Nibor
on Jul 24, 2017 at 1:07:55 pm
WOW! Thank you Simon. That is a truly great solution!
