 | Change default key for snapping?
on Jul 17, 2017 at 5:43:43 pm |
So being that I am an Avid user at work and a Premiere user at home, I try to have key mapping that translates seamlessly between both. One of the most used hotkeys for me is obviously snapping, which in Avid is holding CMD, but in Premiere is holding SHIFT. I would like to change the Premiere setting for it, but for the life of me I cannot figure out how. The only setting I found was "Snap," which simply turns the snapping function on or off, and has nothing to do with the actual hotkey to use it. Thoughts?
 | Re: Change default key for snapping? on Jul 19, 2017 at 5:16:02 pm |
Surely there is a way to do this?
 | Re: Change default key for snapping? on Jul 24, 2017 at 6:13:22 pm |
If you are using a Mac, go to the PremierePro CC top menu and select Keyboard Shortcuts (Option/alt + Command + K) to change the options.
Type SNAP in the search window there to see if any of those listings are what you're looking for.
Joe
Living the SuiteLife!
Stuff for editors
http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl | Re: Change default key for snapping? on Jul 24, 2017 at 6:44:03 pm |
Thank you for the reply Joe, but as I pointed out, I have already tried that and the only hotkey to change is "Snap," which simply turns the snapping function on or off, and has nothing to do with the actual hotkey to use it. I am still at a loss for how to remedy this.
