Concise method to convert 24fps sequence to 23.98 for Blu-Ray output
Bill Boneys
on Jul 13, 2017 at 3:40:06 pm
Hello Cow,
I have a feature length film edited in Premiere Pro CC 2017 at true 24fps, that I will need to deliver at 23.976 for Blu-Ray. What is the proper way to do this ensuring perfect picture quality and audio synch.
Thank you in advance.
Brent Marginet
Re: Concise method to convert 24fps sequence to 23.98 for Blu-Ray output
on Jul 16, 2017 at 4:32:14 am
Is there any particular reason why you can't just make a 24fps BluRay.
There really should be no reason why you would have to use 23.976.
"MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
Take a moment to place a value on them and then maybe add two more.
Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN'T."
Bill Boneys
on Jul 16, 2017 at 5:31:32 am
I need a 23.976 Blu-Ray as part of a deliverables list.
Brent Marginet
on Jul 16, 2017 at 6:06:04 am
Kind of weird that the project would have been shot in true 24 and they would want a 23.976 BluRay.
Getting a proper 23.976fps Video from the True 24 Video would be done through a TeleCine Process. To get the best results your 24fps Video will need to be slowed down by 0.1%. This will change the Real Time Playback of the Video though. As a simple example, if it is exactly 1 hour long at 24fps it will take 1:00:03:14 to play it back at 23.976.
I've never tried AME to see if it can do a proper TeleCine conversion but it couldn't hurt giving it a try. You will want to check for three things. Is the Converted Video 0.1% longer than the original, are there any repeat Frames and are there any blended Frames. The answer should be no to the lat two.
There are a few ways to do the Reverse Process some are hardware based like The Alchemist and possibly a Terranex can do it but don't quote me on that. As far as software goes I can't say I've researched this so start off by testing AME.
Brent Marginet
on Jul 16, 2017 at 6:30:00 am
Just found this.
https://forums.adobe.com/thread/1113078
Roger Averdahl
on Jul 16, 2017 at 10:49:17 am
24fps can be used for Blu-ray without any conversion to 23.976 since 24fps is a supported frame rate for 720p/1080p/4K. I have made several Blu-rays in 24fps and i have bought several commercial Blu-ray discs that are 24fps.
See "Supported video formats" here: https://en.wikipedia.org/wiki/Blu-ray
Why the urge to convert the footage? :)
Mike Kelland
on Jul 19, 2017 at 5:12:44 am
You could try export a ProResHQ of your 24fps film - import that file - right click and re-interpret frame rate to 23.976 - the file now thinks it's a 23.976 clip, it should look and sound fine. Drag the clip to a new 23.976 sequence - set in and out and export a ProRes or MPEG2 etc for a 23.976 BluRay project.
Cheers
Mike
