ProRes Presets for Premier Pro 2017.1.2 vers. 11?
Rachel Pearl
on Jul 11, 2017 at 8:57:44 pm
I just downloaded and am using
Premier Pro CC 2017.1.2 Vers. 11 Oasis.
I am looking to install ProRes sequence presets. Do they exist?
Rachel
Ann Bens
Re: ProRes Presets for Premier Pro 2017.1.2 vers. 11?
on Jul 11, 2017 at 9:23:55 pm
There is not.
Just right click on a clip: New Sequence from Clip.
That will give you a matching sequence for your footage.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Todd Perchert
on Jul 11, 2017 at 9:38:48 pm
If you are on a PC, you won't have any ProRes option, anywhere. If you are on a Mac, I know my PPro defaults to ARRI Cinema as a matching sequence setting for ProRes HQ files. As Ann posted, if you have a ProRes file, drag it onto the New Item icon and it will make a sequence to match.
Good Luck!
TC
Herb Sevush
on Jul 12, 2017 at 11:59:14 am
[Rachel Pearl] "I am looking to install ProRes sequence presets. Do they exist?"
ProRes sequence presets don't exist, but you can make them and save them, if your using OSX, in the New Sequence dialogue window.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
Duke Sweden
on Jul 13, 2017 at 5:12:20 pm
Actually there IS a piece of software that allows PC's to use ProRes. It's called Miraizon DNxHD and ProRes Codecs.
