image moves between identical keyframes
barbara daly
on Jul 11, 2017 at 12:11:59 am
I've had this issue on more than one occasion. I have a photo on the timeline that I am scaling and changing its position. However, between the initial and final move I have two keyframes with identical parameters separated by about a second. This should create a static position for that second. However the image has some movement. I can not find where it's coming from, what's causing it or why. Any ideas would be very much appreciated!
I'm using the latest adobe premiere pro cc updated June 2017.
b
Ann Bens
Re: image moves between identical keyframes
on Jul 11, 2017 at 5:28:29 pm
Set the keyframes to linear. That usually fixes the problem.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
barbara daly
on Jul 11, 2017 at 7:04:27 pm
Oh you are BEAUTIFUL! Thank you.
Turns out one of the keyframes was set at Temporal interpolation: linear, but the Spatial interpolation was set at auto. Once I changed that to linear as well, it solved the problem. That's awesome. Thanks so much!!
b
