Suddenly this "workstation" can't even keep up with my other baby PC
Duke Sweden
on Jul 4, 2017 at 1:42:46 am
This is so aggravating. What I used to be able to do, albeit very slowly, on my crap PC, I can't do on this supposedly superior PC. Rendering is a crapshoot, sometimes it encodes all the way, other times it "fails". about 10 minutes in (this with just some minor lumetri tweaks). Also, I'll be working on something and the source and program monitors will go black. You can see the video of I play it or scrub the timeline, but if I leave it, they go black. I have to shut PPro and restart.
I replaced the graphics card, as mentioned previously. I know what I'm doing as far as that's concerned so I didn't accidentally not set it correctly or anything. I've got about 12 more days to test this thing and I've got a 16 gig RAM chip coming Thursday. But I really dread having to yank my two HDD's out, as well as the new RAM, AND put back the graphics card that came with this.
I thought XPS 8910's were decent, if not top of the line. Does any of this sound familiar to anybody? Am I rendering to the wrong hard drive? Just to summarize,
I have Premiere Pro and Project files on my main HDD, media and cache files on a second HDD, and am encoding to the third HDD.
As far as the source and program monitors going black I don't know what the deal is with that.
Brent Marginet
Re: Suddenly this "workstation" can't even keep up with my other baby PC
on Jul 4, 2017 at 4:55:54 am
Can you post as many hardware specs as possible about your system like current amount of RAM, DDR-X, number and size of sticks, Video Card, CPU, etc. etc.
Also which Version of Windows are you using 7, 8, 8.1 or 10 and 32 or 64bit.
OpenCL or CUDA you know the whole ball of wax.
I will try to help if possible.
I run primarily Mac but I ran into a very similar issue on my PC recently.
I started off reseating everything from Power Connectors to RAM Modules and every expansion card that was in the system. I even reset my BIOS back to the Optimized Factory Defaults and also ran MEM Test with no luck. In the end a new clean install of the OS took about a day once all of Windows Updates were done. I must say though the difference was well worth the time it took to reinstall everything. It seems like it's 10 times faster now.
Here's the MEM Test Link.
http://www.memtest.org
"MY MEDIA MOTO: If you think three copies of your media is enough.
Take a moment to place a value on it and then maybe add two more.
Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN'T."
Duke Sweden
on Jul 4, 2017 at 11:13:51 am
Thanks, Brent. I'll get that information for you, but as I said, even my consumer level PC with 12 gigs of RAM, i5 core processor, integrated Intel graphics card, etc., while slow, never caused these problems. Let me run Speccy and I'll get you the details. For now I can tell you it's running
64 bit Windows 10 with updates,
1 stick of 16 gig of DDR-4 RAM (soon to be 32 gigs),
i7 processor (6700 version. Yeah, I know...),
CUDA (which, after the encode failed and I re-opened the project was told by PPro that my PC doesn't have CUDA and would start in software mode, another glitch the other PC never had).
And, yes, I did install the CUDA driver from Nvidia and updated the drivers for the new graphics card (GeForce 1050).
I guess that's everything you asked for, actually. Thanks again.
Oh, and I just got this 4 days ago. I've got 11 more days to get it right before I bring it back.
Duke Sweden
on Jul 4, 2017 at 11:19:02 am
Here's the specs from Speccy. Hopefully it will format correctly and not be a jumbled mess
Summary
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i7 6700 @ 3.40GHz 30 °C
Skylake 14nm Technology
RAM
16.0GB Single-Channel Unknown @ 1063MHz (15-15-15-36)
Motherboard
Dell Inc. 0WPMFG (U3E1) 28 °C
Graphics
E32-C1 (1920x1080@60Hz)
SONY TV (1360x768@60Hz)
Intel HD Graphics 530 (Dell)
2047MB NVIDIA GeForce GTX 1050 (PNY) 28 °C
ForceWare version: 376.51
SLI Disabled
Storage
931GB Seagate ST1000DM003-1SB102 (SATA) 32 °C
1863GB Seagate ST2000DM001-1CH164 (SATA) 32 °C
465GB Seagate ST3500413AS (SATA) 32 °C
Optical Drives
HL-DT-ST DVD+-RW GU90N
Audio
Realtek Audio
Operating System
Computer type: Desktop
Installation Date: 6/29/2017 3:00:40 PM
Windows Security Center
User Account Control (UAC) Enabled
Notify level 1 - Rare Notify
Firewall Enabled
Windows Update
AutoUpdate Not configured
Windows Defender
Windows Defender Enabled
Antivirus
Antivirus Enabled
Display Name Windows Defender
Virus Signature Database Up to date
.NET Frameworks installed
v4.7 Full
v4.7 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 11.413.15063.0
PowerShell
Version 5.1.15063.0
Environment Variables
USERPROFILE C:\Users\john_
SystemRoot C:\WINDOWS
User Variables
OneDrive C:\Users\john_\OneDrive
Path C:\Users\john_\AppData\Local\Microsoft\WindowsApps
TEMP C:\Users\john_\AppData\Local\Temp
TMP C:\Users\john_\AppData\Local\Temp
Machine Variables
ComSpec C:\WINDOWS\system32\cmd.exe
CUDA_PATH C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0
CUDA_PATH_V8_0 C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0
INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
MIC_LD_LIBRARY_PATH %INTEL_DEV_REDIST%compiler\lib\mic
NUMBER_OF_PROCESSORS 8
NVCUDASAMPLES8_0_ROOT C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0
NVCUDASAMPLES_ROOT C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0
NVTOOLSEXT_PATH C:\Program Files\NVIDIA Corporation\NvToolsExt\
OS Windows_NT
Path %INTEL_DEV_REDIST%redist\intel64\compiler
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\bin
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\libnvvp
C:\Program Files (x86)\Intel\iCLS Client\
C:\Program Files\Intel\iCLS Client\
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL
C:\Program Files\Intel\Intel Management Engine Components\DAL
C:\Program Files (x86)\Intel\Intel Management Engine Components\IPT
C:\Program Files\Intel\Intel Management Engine Components\IPT
C:\Program Files\Intel\WiFi\bin\
C:\Program Files\Common Files\Intel\WirelessCommon\
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\WINDOWS\System32\WindowsPowerShell\v1.0\
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 94 Stepping 3, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 5e03
PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
RG_GPU_FRAMEWORK_ENGINE_RESOURCEDIR C:\Program Files\Red Giant\RGFX
TEMP C:\WINDOWS\TEMP
TMP C:\WINDOWS\TEMP
USERNAME SYSTEM
windir C:\WINDOWS
Power Profile
Active power scheme No energy savings
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 45 min
Turn Off Hard Disk after: (On AC Power) 20 min
Suspend after: (On AC Power) 60 min
Screen saver Disabled
Uptime
Current Session
Current Time 7/4/2017 7:17:02 AM
Current Uptime 1,555 sec (0 d, 00 h, 25 m, 55 s)
Last Boot Time 7/4/2017 6:51:07 AM
Services
Running Adobe Acrobat Update Service
Running Adobe Genuine Software Integrity Service
Running AdobeUpdateService
Running Application Information
Running AppX Deployment Service (AppXSVC)
Running Background Intelligent Transfer Service
Running Background Tasks Infrastructure Service
Running Base Filtering Engine
Running Bluetooth Support Service
Running CNG Key Isolation
Running COM+ Event System
Running Computer Browser
Running Connected Devices Platform Service
Running Connected Devices Platform User Service_5d85f
Running Connected User Experiences and Telemetry
Running Contact Data_5d85f
Running CoreMessaging
Running Credential Manager
Running Cryptographic Services
Running Data Usage
Running DbxSvc
Running DCOM Server Process Launcher
Running Dell Customer Connect
Running Dell Data Vault Collector
Running Dell Data Vault Processor
Running Dell Data Vault Service API
Running Dell Foundation Services
Running Dell Help & Support
Running Dell SupportAssist Agent
Running Dell Update Service
Running Device Association Service
Running DHCP Client
Running Diagnostic Policy Service
Running Diagnostic Service Host
Running Diagnostic System Host
Running Distributed Link Tracking Client
Running DNS Client
Running Function Discovery Provider Host
Running Function Discovery Resource Publication
Running Geolocation Service
Running HomeGroup Listener
Running HomeGroup Provider
Running Human Interface Device Service
Running Intel Bluetooth Service
Running Intel Dynamic Application Loader Host Interface Service
Running Intel HD Graphics Control Panel Service
Running Intel Management and Security Application Local Management Service
Running Intel PROSet/Wireless Event Log
Running Intel PROSet/Wireless Registry Service
Running Intel PROSet/Wireless Zero Configuration Service
Running Intel Rapid Storage Technology
Running Intel Ready Mode Technology
Running Intel Security Assist Helper
Running IP Helper
Running Local Session Manager
Running Network Connected Devices Auto-Setup
Running Network Connection Broker
Running Network List Service
Running Network Location Awareness
Running Network Store Interface Service
Running NVIDIA Display Container LS
Running NVIDIA LocalSystem Container
Running NVIDIA Telemetry Container
Running Peer Name Resolution Protocol
Running Peer Networking Grouping
Running Peer Networking Identity Manager
Running Plug and Play
Running Power
Running Print Spooler
Running Product Registration
Running Program Compatibility Assistant Service
Running Realtek Audio Service
Running Remote Procedure Call (RPC)
Running RPC Endpoint Mapper
Running Security Accounts Manager
Running Security Center
Running Server
Running Shell Hardware Detection
Running SSDP Discovery
Running State Repository Service
Running Storage Service
Running Superfetch
Running Sync Host_5d85f
Running System Event Notification Service
Running System Events Broker
Running Task Scheduler
Running TCP/IP NetBIOS Helper
Running Telephony
Running Themes
Running Tile Data model server
Running Time Broker
Running TokenBroker
Running UPnP Device Host
Running User Data Access_5d85f
Running User Data Storage_5d85f
Running User Manager
Running User Profile Service
Running Windows Audio
Running Windows Audio Endpoint Builder
Running Windows Connection Manager
Running Windows Defender Antivirus Network Inspection Service
Running Windows Defender Antivirus Service
Running Windows Defender Security Center Service
Running Windows Driver Foundation - User-mode Driver Framework
Running Windows Event Log
Running Windows Firewall
Running Windows Font Cache Service
Running Windows Management Instrumentation
Running Windows Media Player Network Sharing Service
Running Windows Presentation Foundation Font Cache 3.0.0.0
Running Windows Push Notifications System Service
Running Windows Push Notifications User Service_5d85f
Running Windows Search
Running Windows Update
Running WinHTTP Web Proxy Auto-Discovery Service
Running WLAN AutoConfig
Running WMI Performance Adapter
Running Workstation
Stopped ActiveX Installer (AxInstSV)
Stopped AllJoyn Router Service
Stopped App Readiness
Stopped Application Identity
Stopped Application Layer Gateway Service
Stopped Auto Time Zone Updater
Stopped BitLocker Drive Encryption Service
Stopped Block Level Backup Engine Service
Stopped Bluetooth Handsfree Service
Stopped Certificate Propagation
Stopped Client License Service (ClipSVC)
Stopped COM+ System Application
Stopped Data Sharing Service
Stopped Delivery Optimization
Stopped Dell Digital Delivery Service
Stopped Device Install Service
Stopped Device Management Enrollment Service
Stopped Device Setup Manager
Stopped DevicesFlow_5d85f
Stopped DevQuery Background Discovery Broker
Stopped Distributed Transaction Coordinator
Stopped dmwappushsvc
Stopped Downloaded Maps Manager
Stopped Dropbox Update Service (dbupdate)
Stopped Dropbox Update Service (dbupdatem)
Stopped Embedded Mode
Stopped Encrypting File System (EFS)
Stopped Enterprise App Management Service
Stopped Extensible Authentication Protocol
Stopped Fax
Stopped File History Service
Stopped Google Update Service (gupdate)
Stopped Google Update Service (gupdatem)
Stopped Group Policy Client
Stopped HV Host Service
Stopped Hyper-V Data Exchange Service
Stopped Hyper-V Guest Service Interface
Stopped Hyper-V Guest Shutdown Service
Stopped Hyper-V Heartbeat Service
Stopped Hyper-V PowerShell Direct Service
Stopped Hyper-V Remote Desktop Virtualization Service
Stopped Hyper-V Time Synchronization Service
Stopped Hyper-V Volume Shadow Copy Requestor
Stopped IKE and AuthIP IPsec Keying Modules
Stopped Infrared monitor service
Stopped Intel Capability Licensing Service TCP IP Interface
Stopped Intel Content Protection HDCP Service
Stopped Intel Content Protection HECI Service
Stopped Intel Security Assist
Stopped Interactive Services Detection
Stopped Internet Connection Sharing (ICS)
Stopped IP Translation Configuration Service
Stopped IPsec Policy Agent
Stopped KtmRm for Distributed Transaction Coordinator
Stopped Link-Layer Topology Discovery Mapper
Stopped LPA Service
Stopped MessagingService_5d85f
Stopped Microsoft Diagnostics Hub Standard Collector Service
Stopped Microsoft Account Sign-in Assistant
Stopped Microsoft iSCSI Initiator Service
Stopped Microsoft Passport
Stopped Microsoft Passport Container
Stopped Microsoft Software Shadow Copy Provider
Stopped Microsoft Storage Spaces SMP
Stopped Microsoft Windows SMS Router Service.
Stopped Mozilla Maintenance Service
Stopped Natural Authentication
Stopped Net.Tcp Port Sharing Service
Stopped Netlogon
Stopped Network Connections
Stopped Network Connectivity Assistant
Stopped Network Setup Service
Stopped NVIDIA NetworkService Container
Stopped Office 64 Source Engine
Stopped Optimize drives
Stopped Payments and NFC/SE Manager
Stopped Performance Counter DLL Host
Stopped Performance Logs & Alerts
Stopped Phone Service
Stopped PNRP Machine Name Publication Service
Stopped Portable Device Enumerator Service
Stopped Printer Extensions and Notifications
Stopped Problem Reports and Solutions Control Panel Support
Stopped Quality Windows Audio Video Experience
Stopped Radio Management Service
Stopped Remote Access Auto Connection Manager
Stopped Remote Access Connection Manager
Stopped Remote Desktop Configuration
Stopped Remote Desktop Services
Stopped Remote Desktop Services UserMode Port Redirector
Stopped Remote Procedure Call (RPC) Locator
Stopped Remote Registry
Stopped Retail Demo Service
Stopped Routing and Remote Access
Stopped Secondary Logon
Stopped Secure Socket Tunneling Protocol Service
Stopped Sensor Data Service
Stopped Sensor Monitoring Service
Stopped Sensor Service
Stopped Shared PC Account Manager
Stopped Smart Card
Stopped Smart Card Device Enumeration Service
Stopped Smart Card Removal Policy
Stopped SNMP Trap
Stopped Software Protection
Stopped Spot Verifier
Stopped Still Image Acquisition Events
Stopped Storage Tiers Management
Stopped Touch Keyboard and Handwriting Panel Service
Stopped Update Orchestrator Service
Stopped Virtual Disk
Stopped Volume Shadow Copy
Stopped WalletService
Stopped WebClient
Stopped Wi-Fi Direct Services Connection Manager Service
Stopped Windows Backup
Stopped Windows Biometric Service
Stopped Windows Camera Frame Server
Stopped Windows Connect Now - Config Registrar
Stopped Windows Encryption Provider Host Service
Stopped Windows Error Reporting Service
Stopped Windows Event Collector
Stopped Windows Image Acquisition (WIA)
Stopped Windows Insider Service
Stopped Windows Installer
Stopped Windows License Manager Service
Stopped Windows Mobile Hotspot Service
Stopped Windows Modules Installer
Stopped Windows Perception Service
Stopped Windows Remote Management (WS-Management)
Stopped Windows Time
Stopped Wired AutoConfig
Stopped Wireless PAN DHCP Server
Stopped Work Folders
Stopped WWAN AutoConfig
Stopped Xbox Accessory Management Service
Stopped Xbox Game Monitoring
Stopped Xbox Live Auth Manager
Stopped Xbox Live Game Save
Stopped Xbox Live Networking Service
TimeZone
TimeZone GMT -5:00 Hours
Language English (United States)
Location United States
Format English (United States)
Currency $
Date Format M/d/yyyy
Time Format h:mm:ss tt
Scheduler
7/4/2017 7:56 AM; DropboxUpdateTaskMachineUA
7/4/2017 8:05 AM; GoogleUpdateTaskMachineUA
7/4/2017 10:08 AM; SystemToolsDailyTest
7/4/2017 1:56 PM; DropboxUpdateTaskMachineCore
7/4/2017 2:05 PM; GoogleUpdateTaskMachineCore
7/4/2017 6:40 PM; Red Giant Link
7/5/2017 2:00 AM; AdobeAAMUpdater-1.0-MicrosoftAccount-john_hopkin68@hotmail.com
7/5/2017 6:00 AM; Adobe Acrobat Update Task
7/5/2017 6:43 AM; PCDDataUploadTask
7/5/2017 6:54 AM; AutoKMS
7/5/2017 6:10 PM; OneDrive Standalone Update Task v2
7/6/2017 6:00 AM; PCDoctorBackgroundMonitorTask
7/6/2017 11:50 AM; Dell SupportAssistAgent AutoUpdate
Dell Cleanup
DropboxOEM
PCDEventLauncherTask
RtHDVBg_PushButton
Hotfixes
Installed
7/4/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.459.0)
Install this update to revise the definition files that are used
to detect viruses, spyware, and other potentially unwanted software.
Once you have installed this item, it cannot be removed.
7/4/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.448.0)
7/3/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.440.0)
7/3/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.421.0)
7/2/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.407.0)
7/2/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.401.0)
7/2/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.400.0)
7/2/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.399.0)
7/1/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.385.0)
7/1/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.384.0)
6/30/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.359.0)
6/30/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.356.0)
6/30/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.345.0)
6/30/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.322.0)
6/30/2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - June 2017 (KB890830)
After the download, this tool runs one time to check your computer
for infection by specific, prevalent malicious software (including
Blaster, Sasser, and Mydoom) and helps remove any infection that
is found. If an infection is found, the tool will display a status
report the next time that you start your computer. A new version
of the tool will be offered every month. If you want to manually
run the tool on your computer, you can download a copy from the
Microsoft Download Center, or you can run an online version from
microsoft.com. This tool is not a replacement for an antivirus
product. To help protect your computer, you should use an antivirus
product.
6/30/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.316.0)
6/29/2017 Definition Update for Windows Defender - KB2267602 (Definition 1.247.301.0)
6/29/2017 NVIDIA - Display - 5/1/2017 12:00:00 AM - 22.21.13.8205
NVIDIA Display driver update released in May 2017
Not Installed
Installation Status Failed
System Folders
Application Data C:\ProgramData
Cookies C:\Users\john_\AppData\Local\Microsoft\Windows\INetCookies
Desktop C:\Users\john_\Desktop
Documents C:\Users\Public\Documents
Fonts C:\WINDOWS\Fonts
Global Favorites C:\Users\john_\Favorites
Internet History C:\Users\john_\AppData\Local\Microsoft\Windows\History
Local Application Data C:\Users\john_\AppData\Local
Music C:\Users\Public\Music
Path for burning CD C:\Users\john_\AppData\Local\Microsoft\Windows\Burn\Burn
Physical Desktop C:\Users\john_\Desktop
Pictures C:\Users\Public\Pictures
Program Files C:\Program Files
Public Desktop C:\Users\Public\Desktop
Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\ProgramData\Microsoft\Windows\Templates
Temporary Internet Files C:\Users\john_\AppData\Local\Microsoft\Windows\INetCache
User Favorites C:\Users\john_\Favorites
Videos C:\Users\Public\Videos
Windows Directory C:\WINDOWS
Windows/System C:\WINDOWS\system32
Process List
acrotray.exe
Process ID 10284
User john_
Domain DESKTOP-1R8PRD3
Path C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\acrotray.exe
Memory Usage 7.92 MB
Peak Memory Usage 7.94 MB
Adobe CEF Helper.exe
Process ID 11032
User john_
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
Memory Usage 88 MB
Peak Memory Usage 108 MB
Adobe Desktop Service.exe
Process ID 10964
User john_
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
Memory Usage 97 MB
Peak Memory Usage 118 MB
AdobeIPCBroker.exe
Process ID 10544
User john_
Path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
Memory Usage 11 MB
Peak Memory Usage 12 MB
AdobeUpdateService.exe
Process ID 4232
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
Memory Usage 9.02 MB
Peak Memory Usage 9.08 MB
AGSService.exe
Process ID 4240
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
Memory Usage 15 MB
Peak Memory Usage 16 MB
ApplicationFrameHost.exe
Process ID 6444
User john_
Path C:\Windows\System32\ApplicationFrameHost.exe
Memory Usage 35 MB
Peak Memory Usage 35 MB
armsvc.exe
Process ID 4900
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
Memory Usage 6.64 MB
Peak Memory Usage 6.71 MB
audiodg.exe
Process ID 13720
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\audiodg.exe
Memory Usage 18 MB
Peak Memory Usage 32 MB
backgroundTaskHost.exe
Process ID 5096
User john_
Path C:\Windows\System32\backgroundTaskHost.exe
Memory Usage 21 MB
Peak Memory Usage 21 MB
CCLibrary.exe
Process ID 3920
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\CCLibrary.exe
Memory Usage 2.68 MB
Peak Memory Usage 2.68 MB
CCXProcess.exe
Process ID 9144
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\CCXProcess.exe
Memory Usage 2.63 MB
Peak Memory Usage 2.63 MB
chrome.exe
Process ID 2648
User john_
Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Memory Usage 116 MB
Peak Memory Usage 199 MB
chrome.exe
Process ID 15140
User john_
Memory Usage 465 MB
Peak Memory Usage 505 MB
chrome.exe
Process ID 15132
User john_
Memory Usage 199 MB
Peak Memory Usage 247 MB
chrome.exe
Process ID 15124
User john_
Memory Usage 140 MB
Peak Memory Usage 187 MB
chrome.exe
Process ID 15116
User john_
Memory Usage 121 MB
Peak Memory Usage 168 MB
chrome.exe
Process ID 12992
User john_
Memory Usage 34 MB
chrome.exe
Process ID 1336
User john_
Memory Usage 140 MB
Peak Memory Usage 179 MB
chrome.exe
Process ID 10428
User john_
Memory Usage 38 MB
Peak Memory Usage 38 MB
chrome.exe
Process ID 11328
User john_
Memory Usage 35 MB
chrome.exe
Process ID 12824
User john_
Memory Usage 65 MB
Peak Memory Usage 84 MB
chrome.exe
Process ID 11772
User john_
Memory Usage 187 MB
chrome.exe
Process ID 14320
User john_
Memory Usage 85 MB
Peak Memory Usage 147 MB
chrome.exe
Process ID 1424
User john_
Memory Usage 39 MB
Peak Memory Usage 41 MB
chrome.exe
Process ID 14080
User john_
Memory Usage 95 MB
Peak Memory Usage 117 MB
chrome.exe
Process ID 12956
User john_
Memory Usage 199 MB
Peak Memory Usage 282 MB
chrome.exe
Process ID 13468
User john_
Memory Usage 9.03 MB
Peak Memory Usage 9.05 MB
chrome.exe
Process ID 13452
User john_
Memory Usage 9.68 MB
Peak Memory Usage 9.70 MB
chrome.exe
Process ID 8448
User john_
Memory Usage 93 MB
Peak Memory Usage 115 MB
conhost.exe
Process ID 7232
User john_
Path C:\Windows\System32\conhost.exe
Memory Usage 96 KB
Peak Memory Usage 9.96 MB
conhost.exe
Process ID 4744
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.66 MB
Peak Memory Usage 5.75 MB
conhost.exe
Process ID 4056
User john_
Memory Usage 8.83 MB
Peak Memory Usage 9.82 MB
conhost.exe
Process ID 12916
User john_
Memory Usage 11 MB
Peak Memory Usage 11 MB
conhost.exe
Process ID 8576
User john_
Memory Usage 8.86 MB
Peak Memory Usage 9.80 MB
CoreSync.exe
Process ID 9160
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\CoreSync.exe
Memory Usage 39 MB
Creative Cloud.exe
Process ID 10204
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
Memory Usage 71 MB
Peak Memory Usage 78 MB
csrss.exe
Process ID 908
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\csrss.exe
Memory Usage 4.98 MB
Peak Memory Usage 17 MB
csrss.exe
Process ID 792
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.25 MB
Peak Memory Usage 7.61 MB
dasHost.exe
Process ID 2748
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\dasHost.exe
Memory Usage 16 MB
DbxSvc.exe
Process ID 3752
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\DbxSvc.exe
Memory Usage 6.29 MB
Peak Memory Usage 6.42 MB
DCCService.exe
Process ID 1008
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Dell Customer Connect\DCCService.exe
Memory Usage 36 MB
Peak Memory Usage 36 MB
DDVCollectorSvcApi.exe
Process ID 13116
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\DellDataVault\DDVCollectorSvcApi.exe
Memory Usage 7.10 MB
Peak Memory Usage 7.12 MB
DDVDataCollector.exe
Process ID 12980
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\DellDataVault\DDVDataCollector.exe
Memory Usage 25 MB
Peak Memory Usage 25 MB
DDVRulesProcessor.exe
Process ID 6944
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\DellDataVault\DDVRulesProcessor.exe
Memory Usage 14 MB
Peak Memory Usage 15 MB
DellSystemDetect.exe
Process ID 8652
User john_
Path C:\Users\john_\AppData\Local\Apps\2.0\7QTX0NL5.H1Y\G386GXKX.RO4\dell..tion_831211ca63b981c5_0008.0005_9a48d74816d64e41\DellSystemDetect.exe
Memory Usage 41 MB
DellUpService.exe
Process ID 7916
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Dell Update\DellUpService.exe
Memory Usage 43 MB
Peak Memory Usage 43 MB
DellUpTray.exe
Process ID 10372
User john_
Path C:\Program Files (x86)\Dell Update\DellUpTray.exe
Memory Usage 56 MB
Peak Memory Usage 64 MB
DFS.Common.Agent.exe
Process ID 12728
User john_
Path C:\Program Files\Dell\Dell Foundation Services\DFS.Common.Agent.exe
Memory Usage 22 MB
Peak Memory Usage 34 MB
DFSSvc.exe
Process ID 4032
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\Dell Foundation Services\DFSSvc.exe
Memory Usage 60 MB
Peak Memory Usage 60 MB
dllhost.exe
Process ID 13664
User john_
Path C:\Windows\System32\dllhost.exe
Memory Usage 11 MB
dllhost.exe
Process ID 10000
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.25 MB
Peak Memory Usage 7.45 MB
dllhost.exe
Process ID 13400
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.95 MB
Peak Memory Usage 5.95 MB
dllhost.exe
Process ID 6668
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 6.29 MB
Dropbox.exe
Process ID 10400
User john_
Path C:\Program Files (x86)\Dropbox\Client\Dropbox.exe
Memory Usage 6.94 MB
Peak Memory Usage 7.04 MB
Dropbox.exe
Process ID 7876
User john_
Memory Usage 122 MB
Peak Memory Usage 130 MB
DropboxUpdate.exe
Process ID 7428
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
Memory Usage 44 KB
Peak Memory Usage 8.56 MB
dwm.exe
Process ID 1300
User DWM-1
Domain Window Manager
Path C:\Windows\System32\dwm.exe
Memory Usage 47 MB
Peak Memory Usage 48 MB
EvtEng.exe
Process ID 3876
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Intel\WiFi\bin\EvtEng.exe
Memory Usage 14 MB
Peak Memory Usage 14 MB
explorer.exe
Process ID 7988
User john_
Path C:\Windows\explorer.exe
Memory Usage 112 MB
Peak Memory Usage 123 MB
fontdrvhost.exe
Process ID 816
User UMFD-0
Domain Font Driver Host
Path C:\Windows\System32\fontdrvhost.exe
Memory Usage 14 MB
fontdrvhost.exe
Process ID 1108
User UMFD-1
Memory Usage 36 MB
HxOutlook.exe
Process ID 12468
User john_
Path C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.8241.41125.0_x64__8wekyb3d8bbwe\HxOutlook.exe
Memory Usage 62 MB
Peak Memory Usage 100 MB
HxTsr.exe
Process ID 11540
User john_
Path C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.8241.41125.0_x64__8wekyb3d8bbwe\HxTsr.exe
Memory Usage 37 MB
Peak Memory Usage 37 MB
IAStorDataMgrSvc.exe
Process ID 6800
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorDataMgrSvc.exe
Memory Usage 46 MB
IAStorIcon.exe
Process ID 4016
User john_
Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorIcon.exe
Memory Usage 35 MB
ibtsiva.exe
Process ID 3760
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\ibtsiva.exe
Memory Usage 4.44 MB
Peak Memory Usage 4.58 MB
igfxCUIService.exe
Process ID 2192
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\DriverStore\FileRepository\ki119562.inf_amd64_6a130ba6366a3570\igfxCUIService.exe
Memory Usage 8.00 MB
Peak Memory Usage 8.23 MB
igfxEM.exe
Process ID 8120
User john_
Path C:\Windows\System32\DriverStore\FileRepository\ki119562.inf_amd64_6a130ba6366a3570\igfxEM.exe
Memory Usage 12 MB
IRMTService.exe
Process ID 3744
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Intel\Intel Ready Mode Technology\IRMTService.exe
Memory Usage 10 MB
Peak Memory Usage 10 MB
isaHelperService.exe
Process ID 3892
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Security Assist\isaHelperService.exe
Memory Usage 3.44 MB
Peak Memory Usage 3.50 MB
jhi_service.exe
Process ID 11044
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL\jhi_service.exe
Memory Usage 6.28 MB
Peak Memory Usage 6.36 MB
LMS.exe
Process ID 2156
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Management Engine Components\LMS\LMS.exe
Memory Usage 12 MB
Peak Memory Usage 13 MB
lsass.exe
Process ID 996
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\lsass.exe
Memory Usage 17 MB
MDLCSvc.exe
Process ID 2248
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\Dell Help & Support\MDLCSvc.exe
Memory Usage 56 MB
Peak Memory Usage 57 MB
Memory Compression
Process ID 4424
User SYSTEM
Domain NT AUTHORITY
Memory Usage 10 MB
MSASCuiL.exe
Process ID 796
User john_
Path C:\Program Files\Windows Defender\MSASCuiL.exe
Memory Usage 9.20 MB
Peak Memory Usage 9.22 MB
MsMpEng.exe
Process ID 4248
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Windows Defender\MsMpEng.exe
Memory Usage 149 MB
Peak Memory Usage 527 MB
NisSrv.exe
Process ID 9608
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Program Files\Windows Defender\NisSrv.exe
Memory Usage 12 MB
node.exe
Process ID 9136
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\node.exe
Memory Usage 62 MB
Peak Memory Usage 72 MB
node.exe
Process ID 4008
User john_
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe
Memory Usage 55 MB
Peak Memory Usage 61 MB
nvapiw.exe
Process ID 6316
User john_
Path C:\Program Files\Dell\DellDataVault\nvapiw.exe
Peak Memory Usage 8.97 MB
nvcontainer.exe
Process ID 3736
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
Memory Usage 22 MB
Peak Memory Usage 23 MB
nvcontainer.exe
Process ID 7236
User john_
Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
Memory Usage 22 MB
Peak Memory Usage 42 MB
NVDisplay.Container.exe
Process ID 1784
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
Memory Usage 12 MB
NVIDIA Web Helper.exe
Process ID 1320
User john_
Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
Memory Usage 1.04 MB
NvTelemetryContainer.exe
Process ID 3836
User NETWORK SERVICE
Domain NT AUTHORITY
Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
Memory Usage 12 MB
nvtray.exe
Process ID 9836
User john_
Path C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
Memory Usage 12 MB
nvxdsync.exe
Process ID 2992
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
Memory Usage 23 MB
PhoneTray.exe
Process ID 10468
User john_
Path C:\Program Files (x86)\Traysoft\PhoneTray\PhoneTray.exe
Memory Usage 14 MB
PresentationFontCache.exe
Process ID 7316
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\PresentationFontCache.exe
Memory Usage 19 MB
Peak Memory Usage 19 MB
PRSvc.exe
Process ID 12636
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\Dell Product Registration\PRSvc.exe
Memory Usage 65 MB
Peak Memory Usage 66 MB
RAVBg64.exe
Process ID 3216
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe
Memory Usage 15 MB
RAVBg64.exe
Process ID 3272
User SYSTEM
Domain NT AUTHORITY
Memory Usage 14 MB
RAVBg64.exe
Process ID 10608
User john_
Memory Usage 748 KB
RAVBg64.exe
Process ID 2296
User john_
Memory Usage 18 MB
RegSrvc.exe
Process ID 3864
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
Memory Usage 9.36 MB
Peak Memory Usage 9.49 MB
RtkAudioService64.exe
Process ID 2688
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Realtek\Audio\HDA\RtkAudioService64.exe
Memory Usage 7.23 MB
Peak Memory Usage 7.67 MB
RtkNGUI64.exe
Process ID 1648
User john_
Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
Memory Usage 14 MB
RuntimeBroker.exe
Process ID 8700
User john_
Path C:\Windows\System32\RuntimeBroker.exe
Memory Usage 47 MB
Peak Memory Usage 63 MB
SearchIndexer.exe
Process ID 8584
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SearchIndexer.exe
Memory Usage 42 MB
Peak Memory Usage 46 MB
SearchUI.exe
Process ID 8280
User john_
Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
Memory Usage 153 MB
Peak Memory Usage 178 MB
SecurityHealthService.exe
Process ID 3852
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SecurityHealthService.exe
Memory Usage 15 MB
services.exe
Process ID 988
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\services.exe
Memory Usage 9.91 MB
SettingSyncHost.exe
Process ID 784
User john_
Path C:\Windows\System32\SettingSyncHost.exe
Memory Usage 3.66 MB
Peak Memory Usage 98 MB
ShellExperienceHost.exe
Process ID 8076
User john_
Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
Memory Usage 69 MB
Peak Memory Usage 70 MB
sihost.exe
Process ID 7260
User john_
Path C:\Windows\System32\sihost.exe
Memory Usage 24 MB
SkypeHost.exe
Process ID 3540
User john_
Path C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.18.614.0_x64__kzf8qxf38zg5c\SkypeHost.exe
Memory Usage 29 MB
Peak Memory Usage 85 MB
smartscreen.exe
Process ID 9884
User john_
Path C:\Windows\System32\smartscreen.exe
Memory Usage 20 MB
Peak Memory Usage 20 MB
smss.exe
Process ID 556
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\smss.exe
Memory Usage 1.13 MB
Peak Memory Usage 1.17 MB
Speccy64.exe
Process ID 9604
User john_
Path C:\Program Files\Speccy\Speccy64.exe
Memory Usage 29 MB
Peak Memory Usage 29 MB
spoolsv.exe
Process ID 2528
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\spoolsv.exe
Memory Usage 16 MB
SupportAssistAgent.exe
Process ID 12840
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Dell\SupportAssistAgent\bin\SupportAssistAgent.exe
Memory Usage 85 MB
Peak Memory Usage 86 MB
svchost.exe
Process ID 1880
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\svchost.exe
Memory Usage 6.77 MB
Peak Memory Usage 7.06 MB
svchost.exe
Process ID 2256
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.93 MB
Peak Memory Usage 8.26 MB
svchost.exe
Process ID 3728
User SYSTEM
Domain NT AUTHORITY
Memory Usage 24 MB
svchost.exe
Process ID 596
User SYSTEM
Domain NT AUTHORITY
Memory Usage 3.77 MB
Peak Memory Usage 3.90 MB
svchost.exe
Process ID 752
User SYSTEM
Domain NT AUTHORITY
Memory Usage 24 MB
svchost.exe
Process ID 2220
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.41 MB
Peak Memory Usage 7.80 MB
svchost.exe
Process ID 1160
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 1204
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.63 MB
Peak Memory Usage 6.77 MB
svchost.exe
Process ID 1400
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 9.61 MB
svchost.exe
Process ID 1464
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 1508
User SYSTEM
Domain NT AUTHORITY
Memory Usage 10 MB
svchost.exe
Process ID 1548
User SYSTEM
Domain NT AUTHORITY
Memory Usage 8.27 MB
Peak Memory Usage 8.36 MB
svchost.exe
Process ID 1716
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.86 MB
Peak Memory Usage 6.08 MB
svchost.exe
Process ID 2976
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.24 MB
Peak Memory Usage 7.24 MB
svchost.exe
Process ID 1836
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.76 MB
Peak Memory Usage 5.94 MB
svchost.exe
Process ID 1888
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 1896
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.74 MB
Peak Memory Usage 7.98 MB
svchost.exe
Process ID 1904
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 1912
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 22 MB
Peak Memory Usage 26 MB
svchost.exe
Process ID 1996
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 19 MB
Peak Memory Usage 22 MB
svchost.exe
Process ID 3332
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.89 MB
Peak Memory Usage 9.26 MB
svchost.exe
Process ID 4780
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.10 MB
Peak Memory Usage 6.17 MB
svchost.exe
Process ID 2168
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.63 MB
Peak Memory Usage 9.79 MB
svchost.exe
Process ID 6108
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.97 MB
Peak Memory Usage 8.06 MB
svchost.exe
Process ID 6064
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.34 MB
Peak Memory Usage 6.55 MB
svchost.exe
Process ID 2044
User SYSTEM
Domain NT AUTHORITY
Memory Usage 8.02 MB
Peak Memory Usage 8.25 MB
svchost.exe
Process ID 6004
User SYSTEM
Domain NT AUTHORITY
Memory Usage 16 MB
svchost.exe
Process ID 5920
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 7288
User john_
Memory Usage 19 MB
svchost.exe
Process ID 5580
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.86 MB
Peak Memory Usage 6.88 MB
svchost.exe
Process ID 3108
Domain NT AUTHORITY
Memory Usage 7.78 MB
svchost.exe
Process ID 6592
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 6572
User SYSTEM
Domain NT AUTHORITY
Memory Usage 21 MB
svchost.exe
Process ID 9052
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.67 MB
Peak Memory Usage 8.70 MB
svchost.exe
Process ID 5540
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.66 MB
svchost.exe
Process ID 5500
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 5492
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.62 MB
Peak Memory Usage 8.79 MB
svchost.exe
Process ID 6952
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 21 MB
svchost.exe
Process ID 3064
User john_
Memory Usage 37 MB
Peak Memory Usage 39 MB
svchost.exe
Process ID 3812
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.55 MB
Peak Memory Usage 5.72 MB
svchost.exe
Process ID 7448
User SYSTEM
Domain NT AUTHORITY
Memory Usage 17 MB
Peak Memory Usage 18 MB
svchost.exe
Process ID 4508
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 5.38 MB
Peak Memory Usage 5.60 MB
svchost.exe
Process ID 4468
User SYSTEM
Domain NT AUTHORITY
Memory Usage 19 MB
svchost.exe
Process ID 7836
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.56 MB
Peak Memory Usage 5.77 MB
svchost.exe
Process ID 7512
User SYSTEM
Domain NT AUTHORITY
Memory Usage 18 MB
svchost.exe
Process ID 7348
User john_
Memory Usage 23 MB
Peak Memory Usage 24 MB
svchost.exe
Process ID 4416
User SYSTEM
Domain NT AUTHORITY
Memory Usage 9.14 MB
Peak Memory Usage 9.41 MB
svchost.exe
Process ID 13236
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 2968
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 3060
User SYSTEM
Domain NT AUTHORITY
Memory Usage 41 MB
Peak Memory Usage 82 MB
svchost.exe
Process ID 2800
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.16 MB
Peak Memory Usage 6.34 MB
svchost.exe
Process ID 3908
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 16 MB
svchost.exe
Process ID 3900
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.00 MB
Peak Memory Usage 7.36 MB
svchost.exe
Process ID 2792
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 13 MB
svchost.exe
Process ID 2712
Domain NT AUTHORITY
Memory Usage 8.82 MB
Peak Memory Usage 8.89 MB
svchost.exe
Process ID 8848
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2652
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.32 MB
Peak Memory Usage 6.56 MB
svchost.exe
Process ID 3024
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2580
User SYSTEM
Domain NT AUTHORITY
Memory Usage 10 MB
svchost.exe
Process ID 2508
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.45 MB
Peak Memory Usage 9.62 MB
svchost.exe
Process ID 2420
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 3828
User SYSTEM
Domain NT AUTHORITY
Memory Usage 19 MB
svchost.exe
Process ID 3820
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 1612
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.87 MB
Peak Memory Usage 6.03 MB
svchost.exe
Process ID 3800
User SYSTEM
Domain NT AUTHORITY
Memory Usage 22 MB
svchost.exe
Process ID 3792
User SYSTEM
Domain NT AUTHORITY
Memory Usage 108 MB
Peak Memory Usage 124 MB
svchost.exe
Process ID 3784
Domain NT AUTHORITY
Memory Usage 9.01 MB
Peak Memory Usage 9.03 MB
svchost.exe
Process ID 3776
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.29 MB
Peak Memory Usage 7.68 MB
svchost.exe
Process ID 3768
Domain NT AUTHORITY
Memory Usage 13 MB
svchost.exe
Process ID 2396
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 2264
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.47 MB
System
Process ID 4
Memory Usage 2.99 MB
Peak Memory Usage 8.04 MB
System Idle Process
Process ID 0
SystemSettings.exe
Process ID 11652
User john_
Path C:\Windows\ImmersiveControlPanel\SystemSettings.exe
Memory Usage 45 MB
Peak Memory Usage 59 MB
taskhostw.exe
Process ID 7452
User john_
Path C:\Windows\System32\taskhostw.exe
Memory Usage 21 MB
unsecapp.exe
Process ID 10884
User john_
Path C:\Windows\System32\wbem\unsecapp.exe
Memory Usage 6.79 MB
Peak Memory Usage 6.79 MB
unsecapp.exe
Process ID 6336
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.90 MB
Peak Memory Usage 6.95 MB
Chris Wright
on Jul 4, 2017 at 11:57:29 am
you need to start from scratch.
for example, did you ever change the old graphics drivers?
is nvidia control panel set to use premiere.exe 'always' while loaded?
have you done a stress test on your components with passmark95 to detect overheating and damaged parts?
at this point, I'd wipe the OS, reinstall only necessary drivers and check temperatures as overheating can cause software failure.
andy patterson
on Jul 4, 2017 at 6:08:20 pm
You might want to wipe and reload everything. It sucks but sometimes that is the only thing that works.
Duke Sweden
on Jul 4, 2017 at 11:39:42 pm
I did the next best thing. I brought it back (it was a previous return, now I know why), and got the XPS 8910 which just went on sale for only 50 bucks more than I paid for the 8910. Currently setting it all up. Sorry about that loooooong list of crap before, I had no idea when I pasted it and posted. Anyway, I'll let you know how this one is going. So far it's not seeing my 3rd HDD and none of my USB ports work except the ones in back that my keyboard and mouse are plugged into, grrrrr....
Duke Sweden
on Jul 5, 2017 at 1:48:51 am
btw, this one is i7 7700 build. It's running a lot smoother, but I can't get one HDD to show up, and it's the one I saved all my stuff on before I wiped the other PC. Aggravating!!! Plus the front USB ports don't work. Oh well, time to watch the fireworks. The ones in my head, that is!!!
Chris Wright
on Jul 5, 2017 at 3:50:27 am
Is the hd motor spinning? Are both sata and power plugged in?
Is sata enabled in bios?
Is the usb header port plugged into the motherboard?
Brent Marginet
on Jul 5, 2017 at 7:07:00 am
Have you gone into the Device Manager to see if there are any Drivers that aren't installed.
You would see an Icon that looks like a question mark or a triangle with an exclamation mark in it.
Dell has really great support and drivers are generally very easy to find on there site.
Duke Sweden
on Jul 5, 2017 at 9:41:31 am
As far as the USB ports, the wires inside this thing are so short that when you lift the power supply module, which you're supposed to do to install a graphics card, it unplugged the USB ports. That's working now. Still trying to figure out the HDD. Everything is plugged in tight, and I reset the BIOS to default, as suggested by Dell, previously as a "fix" for the USB port problem. BTW, the HDD doesn't even show up under disk management, so at this point I have no idea what the problem is. Once I wake up I'll play with it again. I have the cover off anyway since I'm expecting my RAM chip tomorrow.
Duke Sweden
on Jul 5, 2017 at 9:42:58 am
Oh, and it's the 8920. The 8910 is the one I returned.
Duke Sweden
on Jul 5, 2017 at 10:23:17 am
Seriously, in all my years of working with computers this has to be the most unintuitive, unresponsive PC I've ever dealt with!!! I'm trying to take a simple screen shot of my disk management window so you can see what it's showing for the missing hard drive. Press "scrnshot", you say? NO! Nothing happens. All of the "simple" procedures, like pressing alt, windows key, F3 and standing on your head while tapping the screen shot key do nothing. This is sooooo friggin' aggravating!!!
Anyway, disk management shows the "third" HDD as being "Dynamic" rather than "Basic", and "Foreign" rather than "online". There's also the exclamation point in a yellow triangle.
Whether it's actually talking about the missing HDD or some mysterious other HDD, I can't tell you, but I do know that I'm increasingly getting fed up with the constant aggravation of trying to do something that's been simple and second nature for over 20 years and having all these curveballs thrown at me. Maybe I'll take up fishing.
Duke Sweden
on Jul 5, 2017 at 10:31:17 am
And now, once again, after my usual online tirade, the solution suddenly presents itself. Right clicking on the "Foreign" hard drive brings up a menu asking if I want to import the Foreign HDD into the system. Clicking on that then brings up the opportunity to convert it to a "Simple" whatever it's called, and now the hard drive shows up, with all data intact. I have no idea why I always have to make myself look like a fool before the solution appears, but it's worked this way for years. Now, to figure out why print screen isn't printing the screen. Temper tantrum to follow shortly, I believe ;-)
Chris Wright
on Jul 5, 2017 at 11:00:03 am
its Shift+PRNTSCRN or FNT+PRNTSRCN maybe. then CTRL+V(edit paste) in mspaint to see screenshot.
Duke Sweden
on Jul 5, 2017 at 6:11:05 pm
WRONG!!! Contrary to every single link I've followed, that procedure doesn't work. I found the solution on the most obscure message board ever, that has nothing to do with Dell or Windows 10. The solution, which the poster pointed she found nowhere in the official documentation, is to press and hold the fn button and then press print screen, a method supposedly only necessary on laptops. But it worked. Computers....grrrrrr...
Anyway this baby is screaming right now. Can't wait to get my other 16 gig RAM chip tomorrow. Now to shoot something worthwhile.
And as usual, thanks to everybody for trying to help. This was a weird one. Thread closed!
Yair Bartal
on Jul 5, 2017 at 7:30:24 pm
Much more versatile is Snipping Tool from Microsoft.
Duke Sweden
on Jul 6, 2017 at 2:48:31 am
I said THREAD CLOSED!!! 😉 J/K yeah one of the links mentioned the snipping tool but how can that be easier than pressing "fn" and "print screen"?
Anyway, this PC, like the one I brought back, seems to go black in the source and program monitors when I add Cosmo and FilmConvert. Not a big deal as I was just experimenting and prefer not to use those, but it's odd that a much more powerful box than the one I've been using these past few years can't handle that. Do you think the GPU is faulty? It's an NVidia GeForce GTX 1050. It handles everything else smoothly, even plays back 4K with a whole bunch of lumetri tweaks plus a plugin smoothly with no dropped frames, even as I tweak the video. This is one of those questions that is hard to verbalize in google.
Duke Sweden
on Jul 12, 2017 at 3:02:10 am
Here we go again!!! Friggin' AME failing. This isn't even the same PC. It's got an i7 core 7700, and a GeForce 1050ti GPU. WTF!!!!
Brent Marginet
on Jul 12, 2017 at 4:01:12 am
Is it possible that this is just a problem with Windows 10.
I've been running Win 7 and won't update because of all of the Win 10 issues I hear about.
"MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
Take a moment to place a value on them and then maybe add two more.
Chris Wright
on Jul 12, 2017 at 5:56:01 am
Didn't you say you were using a bunch of plugins? You need to update them.
