Import as dual mono
Matt Scholes
Import as dual mono
on Jun 26, 2017 at 9:37:35 pm
I know how to change a one track stereo clip to dual mono in PP, but I have literally hundreds of clips that I want to look through, so I want to import them as dual mono, not stereo and don't have to go through changing every one separately.
Any ideas?
If you aren't willing to change you shouldn't be editing" - Richard Marks
John Pale
Re: Import as dual mono
on Jun 27, 2017 at 12:36:41 am
Just change your preference setting to mono before importing. It's under Media, I believe.
Mark Whittle
on Jun 28, 2017 at 9:25:03 am
Hi Matt,
In my case my main camera has cam mic on L channel and Radio mic on R. Quite a lot of the time the radio isn't in use so this track is mute. By default it imports as a .mov with a single stereo file.
What I do is select all the files I want to import in the media browser, import into one bin, then select them all, right click and choose Modify > audio channels.
It changes clip channel format to Mono, Number of Audio clips: 2.
If I've done a shoot with only one track I can just uncheck the Clip 2 R selection and only have one track.
I often shoot with multiple cameras so I like to choose the settings manually depending on the camera. You can save a preset for each camera if you want to make settings quicker.
Hope that helps.
Mark W.
Matt Scholes
on Jun 28, 2017 at 1:31:16 pm
Ok, that makes sense.
