Opacity fades & displacement of objects
Charles Smiley
on Jun 20, 2017 at 6:06:09 pm
I occasionally use Premiere Pro CS5 with Windows 7-64.bit-pro on old Standard-Def video projects that need an update. One little issue that bugs me is the following...
When I have a small floating object, Luma-keyed over an SD static graphic, I sometimes make it fade out with the Opacity control -- instead of just ending the object's clip on the timeline. It works OK, but there is always a small positional displacement of the "floating" object that is just barely noticeable.
Is there a cure for this - has anyone else noticed this?
