Lumetri Profile in External File?
Daniel Evans
on Jun 13, 2017 at 5:41:02 pm
If I have a hundred videos of the same speaker and environment, and I anticipate I may need to adjust the color multiple times during post-production, is there a way to externalize the Lumetri settings so I can change them all at once? (That is, have the color settings live in, say, an XML file that I can tweak and is sourced by Premiere when loading a project?)
Sorry if this is a newbie question.
Thanks for any help!
Chris Wright
Re: Lumetri Profile in External File?
on Jun 14, 2017 at 1:41:13 am
I would just use master clips. they would affect all subclips automatically. select all, paste lumetri settings.
https://helpx.adobe.com/premiere-pro/using/master-clip-effects.html
if you want to program and code, if you you unzip the premiere project file(it's a .gz), you can actually edit in a text file.
