Do I edit in 4k then export to HD or edit the 4k in HD timeline?
Anthony Sneed
on Jun 3, 2017 at 9:08:08 pm
I have a project where about half of it was shot in 4k or above and the rest is in HD. There's some parts where I blow up some of the HD so I think my final output SHOULD be HD. It's a short film and I plan on taking it to festivals.
Should I bring the 4k footage into the HD timeline then just scale it down, or should I edit in 4k, then in the end out to HD?
Does it matter or is it exactly the same?
Shane Ross
Re: Do I edit in 4k then export to HD or edit the 4k in HD timeline?
on Jun 4, 2017 at 8:31:35 am
Editing 4K in an HD timeline means you can scale the 4K better...zoom in if you need. If you edit in a 4K timeline, you can't do that, not without losing quality but scaling over 100%. If your deliverable is HD...or even 2K DCP...edit in those frame sizes. Edit in the deliverable frame size.
Shane
Little Frog Post
Ann Bens
on Jun 4, 2017 at 11:09:48 am
Downside to this when wanting to use Warp Stabilizer you will have to nest first.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Anthony Sneed
on Jun 4, 2017 at 6:44:05 pm
Cool thanks for the advice
