Repeated Crash when exporting .h264
Tom Sefton
on May 31, 2017 at 4:38:41 pm
Timeline made up of Red Epic-W, Epic Dragon and Scarlet footage at a mixture of 4K, 5K, 6K and 8K resolution final output from the r3d files. Some clips are 75fps but with speed changes and optical flow. Lumetri LUT loader has a basic LUT on some of the clips.
Comp resolution is 4K in width but 1200 high for a Widescreen projection.
Audio is 5.1 with a .wav imported via Audition.
Exporting to a custom resolution for upload to vimeo. h264 dual pass, 15mbps target 20 max.
Crashes after around 70% progress - not just Adobe Media Encoder and Premiere, but the whole Mac, requiring a restart.
Footage stored on GTech Studio XL, exporting to desktop - plenty of space there for the file <800MB.... Mac pro 2013, 6 core, 32 GB RAM, D700s.
Any thoughts?
Co-owner at Pollen Studio
http://www.pollenstudio.co.uk
Michael Sacci
Re: Repeated Crash when exporting .h264
on May 31, 2017 at 5:46:19 pm
Is there a difference with the media around that point? A different filter? If an export keeps failing at roughly the same point I would look closely at the words footage.
Tom Sefton
on May 31, 2017 at 8:31:23 pm
Got the timeline to export to prores 4444 - seems like it was crashing as it hits the epic-w 8k footage. Prores to h264 has worked ok so presume it's the step from r3d to h264 with 8k epic-w footage causing problems...
Anyone else seen this?
