Randomizing Position and Y Axis Keyframes
Christian Phelps
on May 25, 2017 at 2:12:07 am
Hey guys,
I'm working on a project in which I have about 200 individual graphic images popping onto the screen and then all of them are key framed to slide up on the y axis until it exits frame.
I do not know how to randomize this effect as I want each image to start at a random area of the frame and then fly up the y axis. (Right now they're all duplicates following the same path as the first image)
basically I am asking for an easy way to randomize the image's starting position, and then have it slide up the y axis at the same rate as the other images.
Thanks in advance guys,
C
Alex Udell
Re: Randomizing Position and Y Axis Keyframes
on May 25, 2017 at 11:50:00 am
Hey Christian....
three's no scripting or expressions in Ppro....
so this would be something that would have to be done by hand here.
If you are looking fro some sort of automation...
You might be able to accomplish it with AE via a script....
but I couldn't tell ya exactly how...
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Eric Santiago
on May 25, 2017 at 11:52:26 am
Do it all in AE, its a ton o fun ;)
